Z06 Vette LS7 piston failure
Old Jan 28, 2008 | 08:46 PM
fossil's Avatar
Default Z06 Vette LS7 piston failure
Z06 piston failure on #6 with a supercharger. Piston coming apart and scoring cylinder walls badly.
Attached Thumbnails Z06 Vette LS7 piston failure-2007-zo6-corvette-061.jpg   Z06 Vette LS7 piston failure-2007-zo6-corvette-062.jpg   Z06 Vette LS7 piston failure-2007-zo6-corvette-063.jpg
Old Jan 28, 2008 | 08:58 PM
Greg Fell's Avatar
time to forge it! can the block be cleaned up with a bore/hone, or is it too deep?
Old Jan 28, 2008 | 09:04 PM
fossil's Avatar
I will measure tomorrow, just tore down tonite. It will easily catch a finger nail on both scars. Compression was 85psi and will not pass a leak down test.
Old Jan 28, 2008 | 10:49 PM
Unaffliated Racing's Avatar
pm sent
Old Jan 29, 2008 | 12:29 AM
Steve - Race Eng's Avatar
LS1TECH Sponsor
Default scars
Take a good look at that cylinder wall when you remove the piston. It may be cracked. I can resleeve the block if it is cracked or won't clean up. Don't junk it.
Steve
__________________
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
Old Jan 29, 2008 | 07:47 AM
1.8t's Avatar
What was the cause of failure?
Old Jan 29, 2008 | 08:22 AM
Jon5212's Avatar
Too much boost? Ran lean?
Old Jan 29, 2008 | 08:32 AM
fossil's Avatar
Ran lean.....
Old Jan 29, 2008 | 08:36 AM
bandit1's Avatar
good luck with it hope for the best
Old Jan 29, 2008 | 09:16 AM
Jon5212's Avatar
Ran lean.....
Oops ... well you can't blame the motor for that!
Old Jan 29, 2008 | 09:58 AM
fossil's Avatar
The only positive is that this is a customers engine and not mine.
Old Jan 29, 2008 | 12:54 PM
OneQuickCoupe's Avatar
That's the spirit.
D.J.
Old Jan 30, 2008 | 09:03 PM
cam75w/ls1's Avatar
Sure looks lean on one cylinder. Injector problem?? Intake leaking? Would suck to fix the motor and have it do it again...
