Do LSX blocks come with..........
I know the LSX block comes with its own Cam retainer plate, but does it come the front timing cover?
What are guys receiving with this block as far as stuff like that?
Thanks,
Jeff
Thanks,
Jeff
LS1Tech Sponsor
LS1Tech Premium Sponsor
The LS1 front cover will make for another problem with what you'll do wth the cam sensor. If you're wanting to save some money I'd go with the standard GM LS2 front cover setup!
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic110569_2.gif)
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
![Nut swinger](https://ls1tech.com/forums/images/smilies/nutswinger.gif)
LS1Tech Sponsor
There have been less than 4 with machining or casting issues. Like I said earlier the reason production was halted was to make some adjustments on the tooling. Any and all blocks with the defect caused by the tooling issue were rejected during intial inspection.
Brian Thomson had one on the dyno last week with over 2000 horsepower. If you want to build one with more than that you should not have any problems if you rely on a competiant builder
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Robin
If you don't know, don't say anything.
Thanks! So I guess my next purchase is the LS2 timing cover and extension harness from Katech.
What about oil pans? The motor is going into an F-body. Do I need an LS2 oil pan or will an LS1 oil pan work?
Thanks,
Jeff
Your LS1 pan and related parts will transfer over! We've got the timing cover and extension harnesses in stock. Let me know if I can help!
__________________
Your information is incorrect. Now that is a new one. I have heard all the rumors, but when I dig in to find out the truth it's always someone knows someone whos buddy knows someone who heard....
Brian Thomson had one on the dyno last week with over 2000 horsepower. If you want to build one with more than that you should not have any problems if you rely on a competiant builder![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Robin
Robin
![Punch](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_punch.gif)
LS1Tech Sponsor
