What are my block options for aluminum block 454?
I had Steve at Race Engine Development Oceanside, CA. do a Darton Dry sleeved LS2 block for me.
4.185 bore with a 4.125 stroke. Block looks sweet but still waiting on pistons for the rotating ***. Staying NA for a little street fun, well maybe the track to see what she'll do
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
We have done many 455ci builds. Our 455ci motor uses our own custom dry sleeve with a brand new LS2 block. A 427 is a blast to drive but the torque and response you get from a 455 is incredible!
Zach
Zach
How does this setup adress problems others have brought up with piston skirts coming out the bottom of the bore , and the piston pin intruding on the ring pack . How much for a short block ?
![Google](https://ls1tech.com/forums/images/smilies/google.gif)
Maybe off topic, but don't laugh at the oval piston idea! Honda did exactly that with a motorcycle engine over 20 years ago!!! And it revved to OVER 20,000 RPM (Yeah, twenty thousand!) They did this because the Grand Prix rules then in effect banned anything over 4 cylinders. So Honda put 2 (!!) connecting rods on each oval shaped piston, equipped the motor with 4 oval pistons to meet the rules,and ran 8(!)valves per cylinder, effectively making it an in-line, or straight, 8 cylinder engine (32 valves, 8 connecting rods, etc.) And, it worked. The hardest part was making the piston rings fit and seal properly, but they eventually DID make it work. Many who saw and heard it said that when it was wound all the way up, it sounded like a 2 stroke!! (A 4 stroke at 20,000 R's would have 10,000 power strokes per minute, same as a 2 stroke at 10,000 RPM! Just food for thought!!![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
That was the NSR750.
