510cid small block
Old Jun 30, 2008 | 10:27 PM
  #61
SPDMETL's Avatar
Wouldn't F/I cure any cylinder head deficiencies ?
Old Jun 30, 2008 | 11:42 PM
  #62
BigBronco's Avatar
Originally Posted by needadvice
what was the difference in HP with the LS7 intake and the Beck intake....on motor?
The motor did not turn enough rpm to see the large difference in the intakes. Because of plenum and runner size, the numbers stayed nearly the same. Only difference started was a slight pull from 5800 rpm to 6500, but NOT by much at all.
With a 6,500 redline, the Beck never got enough time and RPM to actually "work".
Old Jun 30, 2008 | 11:43 PM
  #63
BigBronco's Avatar
Of course. But with adding F/I, cylinder pressure becomes a battle with Cylinder rigidity and keeping the heads bolted down flat to the block. (Losing head gaskets, etc.)
That is the worry people were discussing earlier, but these motors have seen 900 horsepower and have held up pretty well.
