Milling ET LS7 Heads, How many CC per thou.
I can't tell you how many thou. to mill to remove 1cc from you heads, but you can determine how much to mill to get to a desired compression ratio if you are shooting for a target CR. I believe the Formula goes like this. Anyone correct me if I am wrong on anything.
Compression Ratio = Displacement Ratio + 1
Displacement = Cylinder Volume/Chamber Volume
Amount to mill = New Displacement Ratio - Old Displacement Ratio/New Displacement Ratio X Old Displacement Ratio X Stroke
The following users liked this post:
Rich2342 (03-09-2023)
I never thought I'd be saying this but I think I need more compression in my turbo motor. After talking to a couple of well respected turbo engine builders I may have missed the boat when it comes to power/compression. And this ain't your normal Ls1 motor. We've made 1100hp @ 13# of boost. We're looking to raise the compression just alittle....
