View Poll Results: LSX Aluminum Block Standard or Tall
Standard
105
70.95%
Tall Deck
43
29.05%
Voters: 148. You may not vote on this poll
Aluminum LSX Block Poll
Old Jan 21, 2009 | 10:34 AM
  #101
JL ws-6's Avatar
Race your car!
Erik, the RHS block won't actually fit a 4.6 stroke then?
What about a 4.5?
Old Jan 21, 2009 | 10:55 AM
  #102
racer7088's Avatar
No the RHS does have the oil galley moved over a little for that.
Old Jan 21, 2009 | 11:17 AM
  #103
JL ws-6's Avatar
Race your car!
What are your thoughts on the RHS block Erik? I've been looking at and am waiting to see what the alum lsx block will offer before starting anything new.
Take it to PM if need be.
Old Jan 21, 2009 | 11:35 AM
  #104
Haans249's Avatar
Didn't realize they moved the oil galley. I must've not listened well when I talked with someone about the block. Good news.
Old Feb 28, 2009 | 06:23 AM
  #105
BAD Z's Avatar
Tall Deck all the way
Old Mar 1, 2009 | 12:13 PM
  #106
Qwiknotch's Avatar
Robin...
tall deck (9.5 - 9.8), and design the block to use a standard sbc oil pump, so not everyone will have to go out and spend $5k for a dry sump.
Old Mar 1, 2009 | 12:27 PM
  #107
scatillac's Avatar
Default Std. Deck
You've already got one. Just lower the price of the C5R case to ~$3750 or so!
Old Mar 1, 2009 | 08:04 PM
  #108
Anonymous's Avatar
10 second playa
That won't happen.
Robin, any updates on the LSX Aluminum block?
I know GM is in trouble $$$ wise, but I hear GMPP is actually a profitable component of GM.
PM me if you want.
Old Aug 14, 2009 | 01:26 AM
  #109
M275's Avatar
Any updates?
Old Aug 14, 2009 | 08:56 AM
  #110
GIGAPUNK's Avatar
GM went bankrupt
Fiat is coming
Old Aug 14, 2009 | 10:23 AM
  #111
Robin L's Avatar
LS1Tech Sponsor
Originally Posted by M275
Any updates?
The Aluminum block is on the back burner. The priority is the LSX Heads and Intake as well as the LSX Crate Engines.
With the cuts there are only so many people available and they are working to get high priority products out in the market.
Robin
Old Aug 14, 2009 | 11:05 AM
  #112
Cliff's Avatar
Robin
That's to bad.
Old Aug 14, 2009 | 11:17 AM
  #113
JL ws-6's Avatar
Race your car!
Just do what I'm looking at doing.. have a C5R or a LS7 converted to 6 bolt and go with it.
Old Aug 14, 2009 | 12:54 PM
  #114
ATVracr's Avatar
World tall deck.
Old Aug 14, 2009 | 04:09 PM
  #115
JL ws-6's Avatar
Race your car!
Only problem with that, is that it has the goofy head bolt pattern and I don't want to be commit to running their head if I do the 6 bolts/cyl.
Honestly, I would love to go with the RHS block but with the limited bore size I can't get the CI I want to run.
ERL block is starting to look like a more viable option at this point. The sleeves can be made a little longer.
Honestly, I would love to just go lsx but I don't want the weight of the iron block. The damn C5R block is an expensive piece, dart billet is even worse at this point it's out of consideration, just too much $ for what I want to do/have to spend.
Old Aug 14, 2009 | 04:13 PM
  #116
Anonymous's Avatar
10 second playa
What is the max bore for the RHS block?
How much $ is the RHS block?
Then what is the max bore for the Dart Billet block?
How much $ is the Dart block?
Old Aug 15, 2009 | 11:58 AM
  #117
JL ws-6's Avatar
Race your car!
The RHS block is around the 4K mark, and the max bore is 4.16 on that one, but you can get that in a tall deck.
The dart billet block last time I looked into it was over 7 grand, but I think you can go 4.18 on that, if I remember right. That block also is available in any deck height, raised cam, shifted oil galley for stroke clearance, hell if you want no coolant passages at all you can do that too.
The dart billet piece, definately hs a killer item, but you're probably looking at 10 grand for the block and the machine work by the time you're done. Way out of my budget range at this point.
Old Aug 15, 2009 | 07:05 PM
  #118
melsie68's Avatar
Originally Posted by Busted Knuckles
Tall deck, raised cam, spread pan rails. Needs to be big enough for 500+ cubes.
Hell, if you're gonna dream, dream big.
I agree, what is the point of a tall deck without a raised cam? I suppose we can go smaller and smaller on the rod journals? I would hate to have a long stroke just to end up with a compromise using a small base circle cam and connecting rods that need to be clearanced.
Old Aug 15, 2009 | 10:51 PM
  #119
Anonymous's Avatar
10 second playa
I guess this is the way to go if you want a beefy Alum. block?
It is still $2,250 cheaper than a C5R block and probably stonger, plus it already has the GM 6 bolt head pattern.
Or am I missing something?
Old Aug 16, 2009 | 09:38 AM
  #120
JL ws-6's Avatar
Race your car!
Problem is the limitation on the bore, you can only go 4.16 with it. But, a tall deck on that block and I would think a square 4.125/4.1 motor should be possible, givign ya a 434
Should work, at least I'd think.
I just don't know about the headers and whatnot, will the regular ones fit, if not who's making some that do, and what are they gonna cost, what about everything else on the motor too..... that type of thing.
