View Poll Results: LSX Aluminum Block Standard or Tall
Standard
105
70.95%
Tall Deck
43
29.05%
Voters: 148. You may not vote on this poll
Aluminum LSX Block Poll
Old Sep 25, 2008 | 04:54 AM
  #81
ATLSS's Avatar
Originally Posted by Shawn @ VA Speed
It's amazing that i can build a 2500 hp sbc using a Brodix aluminum block,off the shelf Lunati pro series crank and off the shelf Lunati billet rods-put over 200 passes on it with no bearing problems but i cant get 20 passes on an LSX block making 1800hp using the same components-can you explain why i need a center counterweight billet crank,aluminum rods and a bunch of custom stuff to do the same with the LSX block?
Thank India, and the greed of an American company.
Buy Warhawk or C5R next time.
Old Sep 25, 2008 | 04:37 PM
  #82
s/c'd cav's Avatar
standard and oil squirters
Old Sep 25, 2008 | 09:30 PM
  #83
SMKN TA 95's Avatar
Originally Posted by Robin L
I heard today that they were doing a trial on the mold. Should be very soon. They didn't tell me which head but I assume they are all in the same phase.
Robin
So how different are the 6 bolt LSX heads they are casting currently compared to the GM 6 bolt LSX heads you have on your engine
Old Sep 27, 2008 | 08:12 AM
  #84
Robin L's Avatar
LS1Tech Sponsor
I have not seen those heads yet. I saw the plastic models at SEMA and PRI. I did study them during any breaks in the action. From what I am told the small port version is similar to what I have now. I was told the changes are subtle.
The one that I want to see is the large port version. I hear the numbers are 20 to 30 higher than the heads that I have now.
I hope they are close as I would like to use my current intake manfold when the new heads become available.
Robin
Old Sep 28, 2008 | 09:34 PM
  #85
WhiteS13's Avatar
standard.
Old Jan 13, 2009 | 09:11 PM
  #86
Robin L's Avatar
LS1Tech Sponsor
Originally Posted by pman
what have i found?
LOL, nice try while I am not sure who's that is it' not like any LSX that I have seen.
Oil galleys are not in the same spot as the iron block. Also the LSX block has more bolt bosses for a motor plate that the block in the picture is missing.
Also the LS-X is not the same as the trade marked LSX logo.
I don't remember the oil galleys on the RHS/Comp block.
Robin
Old Jan 13, 2009 | 09:12 PM
  #87
GIGAPUNK's Avatar
Priority mains and Aluminum!? sweet. Any details pman? It's not nice to tease.
Old Jan 13, 2009 | 09:35 PM
  #88
Busted Knuckles's Avatar
Tall deck, raised cam, spread pan rails. Needs to be big enough for 500+ cubes.
Hell, if you're gonna dream, dream big.
Old Jan 13, 2009 | 10:16 PM
  #89
GIGAPUNK's Avatar
If you voted standard deck...
You're a wuss.
Old Jan 14, 2009 | 06:53 AM
  #90
deuce_454's Avatar
what would the difference between an LSx aluminum block and a C5R block be??? 2 additional head bolts???
Old Jan 14, 2009 | 11:59 AM
  #91
ZZebes's Avatar
that and not 9k with a special alloy
Old Jan 14, 2009 | 09:09 PM
  #92
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
This needs to come out soon. I'd absolutely love to have something like this. Either version would be good, but a tall deck would be the best.
Old Jan 15, 2009 | 12:47 AM
  #93
s/c'd cav's Avatar
my twins will more than make up for a tall deck large CI motor
not to mention keep under hood clearance reasonable
Old Jan 15, 2009 | 05:52 AM
  #94
Devil z's Avatar
check out vid
http://videos.streetfire.net/video/C...run_282463.htm
Old Jan 15, 2009 | 07:17 AM
  #95
Robin L's Avatar
LS1Tech Sponsor
That is not our block. Someone is playing with you. Notice the lame attempt to cover up the casting number under the GM Logo.
It's a production block of some kind.
It doesn't have any of the extra bolt holes in the front or back of the block.
Oil galleys are wrong also.
Nice try......
Robin
Old Jan 15, 2009 | 08:09 AM
  #96
JL ws-6's Avatar
Race your car!
Robin what is the time frame for the alum block to be out? I'm waiting to start anything until this is available, I want to see what this will have to offer vs the RHS/Comp block.
Old Jan 15, 2009 | 11:57 AM
  #97
OWN3D BY MY PROF!
Nice try......
Robin
Robin,
I noticed a few of those things. I was simply referring to my desire to have an aluminum LSx block that will hopefully be priced close to the iron version.
Old Jan 20, 2009 | 09:02 PM
  #98
DuraDiesel's Avatar
When will the Aluminum LSX be available to purchase?
Old Jan 21, 2009 | 09:38 AM
  #99
racer7088's Avatar
Robin, I would do at least 5.800 long sleeves in it so more stroke and better pistons can be used even on the normal deck height version. I know the Sunnen hones have no issue at all honing a bore like that in an LSx style block with the right machining and honing overtravel built in as we do it everyday.
If you did a tall deck then the raised cam would be nice as well as making sure the oil galley won't get hit by the stroke ala RHS.
Old Jan 21, 2009 | 09:43 AM
  #100
Haans249's Avatar
Great point. Its weird that RHS didn't move the oil galley outward so that clearancing won't cut into it. Would make it a little "easier" to fit a 4.6" stroke in there.
