Generation V Internal Engine 2013-20xx LT1
Lt4
Old Jan 13, 2014 | 03:00 PM
UltimaCH's Avatar
Default Lt4
The new LT4 is out in the Z06
http://www.gmhightechperformance.com...e_z06_and_c7r/
Not much talk about this new GenV engine...
Old Jan 13, 2014 | 03:55 PM
87silverbullet's Avatar
That's one sick *** ride! Just when you thought GM was done........think again.
Old Jan 14, 2014 | 12:57 PM
SSCamaro99_3's Avatar
Considering the official anouncement was yesterday morning, and final testing and certification is not complete, there isn't a whole lot to talk about.
Old Jan 15, 2014 | 02:25 PM
Wnts2Go10O's Avatar
so this is another "how much hp will it actually have" thread?
Old Jan 15, 2014 | 04:42 PM
I'l play. Considering that the LS9 was touted as above 600 when announced, I see no way that they bring this in at less than the LS9. Just my guess.
Old Jan 15, 2014 | 11:17 PM
Wnts2Go10O's Avatar
blower that is .3L less in displacement than TVS on the LS9, heads that flow less stock than the LS9, and smaller cam plus DI = same or slightly under. how much boost does a stock ls9 make?
Old Jan 16, 2014 | 01:41 PM
Mostly a friendly guess. It is touted as a more effecient unit. I doubt we can make a comparison of the heads yet. Ls9 was 10.5 psi. Initial report for LT4 is at least 9.5psi. Should be fun to find out as more information becomes available.
Old Mar 17, 2014 | 05:18 PM
Bring the Noise's Avatar
Stainless steal headers stock - check; 10.0:1 compression - check; Forged pistons, and rods - check; TI valves - check; Stronger heads vs the LT1 - Mentioned Roto casting (so possible); Direct Injection, Active Fuel Management, and Variable Valve Timing - check; & Better clearance for the SC- check (listed as only 1 inch taller then the N/A LT1's manifold now thats quite a feature).
3 different downforce packages as factory options.... interesting indeed.
To be honest I'ld guess that the C7 Z06 will either match or beat the C6 ZL-1 off the line and out of corners.
Because VVT + boost is a hell of a low end torque combo down low and allows for a higher rpm peak hp (and an altogether stronger power band when setup correctly).
Youtube
link for the vid if you're having problems with it not loading correctly off of the gmhtp site (kinda a flash backup to the silverlight version)....
Old Mar 19, 2014 | 11:08 AM
UltimaCH's Avatar
Interesting. Thanks for posting the video
