Generation V Internal Engine 2013-20xx LT1
L83: swapping to LT1 cam worth it?
Old Jan 21, 2022 | 09:12 PM
Scarebird's Avatar
Default L83: swapping to LT1 cam worth it?
Picking up a low mileage 2019 L83 / 6L80E takeout to swap into a 1971 Lemans ragtop. Definitely keeping the VVT and AFM as wife and I are retiring to Lisbon with it's $8/gallon fuel. The cam in the L83 is small, wondering if a 6 degree increase in duration is worth the hassle?
Old Jan 21, 2022 | 09:57 PM
Call Cam Motion and ask them. They are pretty up on the DOD/AFM/VVT cams
Old Jan 26, 2022 | 02:48 PM
Project GatTagO's Avatar
Honestly, I wouldn't bother!
Andrew
Old Jan 26, 2022 | 03:10 PM
Scarebird's Avatar
I am starting to lean that way. If I have to pull the heads it will be a hard no.
Bobby Biancaniello did reply - he is asking questions concerning the build and other components. I thank him for that.
Old Jan 27, 2022 | 12:00 PM
Scarebird's Avatar
Update: I was told by Cam Dynamics that with keeping the existing torque convertor, valve springs, etc it would be best to retain the original L83 cam.
Old Feb 9, 2022 | 06:05 PM
thunderdan74's Avatar
Any enigine I would have out of a car would rapidly have AFM deleted. It’s a ticking time 💣
Old Feb 11, 2022 | 11:24 AM
gagliano7's Avatar
Agreed!!!
Old Mar 13, 2022 | 09:18 PM
Scarebird's Avatar
I did delete the DOD; seems other than online badmouthing GM is also slowly phasing it out.
I did put in the LT1 cam from Michigan Motorsports
