Generation V Internal Engine 2013-20xx LT1
Stripped HEADBOLT
Old Oct 22, 2023 | 10:46 PM
z28_YOU_HO's Avatar
Default Stripped HEADBOLT
Have my old ladies l83 torn apart due to a leaky head gasket - was seeping coolant out of the rear of the head. Got everything cleaned up and went to reassemble today and #9 bolt just spin and spins. (Guess I know why it was leaking now, I am assuming the head has been off before)
Before I do a time-sert I am going to attempt to throw a stud in and pray it will hold.
This brings me to my question. WHAT SIZE HEAD STUD DO I NEED?
I just want to verify I am ordering the right size and am having a hard time finding exactly the right answer.
Old Oct 23, 2023 | 11:38 PM
91 Z28's Avatar
Drill it out and put a heli coil in there and put the bolt back in on assembly
Old Oct 24, 2023 | 07:18 PM
z28_YOU_HO's Avatar
they don’t make a Helicoil in the correct size.
I believe the bolt size is m11 x 2.0 ??? (My original question)
I am just wanting to get this thing back together so we can go trade it in on a new Denali
Old Oct 24, 2023 | 09:30 PM
91 Z28's Avatar
They make time sert thread repair kits for M11x2.0 they aren't cheap tho. I'd take it to a guy to have it fixed properly. Fix it once and fix it right.
If you just drill it out and stuff a bigger bolt in there it's gonna suck for the next who buys that thing
Old Oct 31, 2023 | 03:47 PM
oange ss's Avatar
Gen V head bolts are 12mmx1.75
Old Nov 1, 2023 | 09:47 PM
z28_YOU_HO's Avatar
thank you!
Old Nov 2, 2023 | 06:50 PM
dixiebandit69's Avatar
thank you!
Just so you know, if you DO find a stud that size, those stripped threads will not hold when you torque the nut down. Just get a Helicoil/ Timesert/ etc.
Old Nov 3, 2023 | 08:35 AM
SAPPER's Avatar
You don't just heli-coil or time-sert. these blocks. The threads are countersunk into the block. You have to purchase a kit. Time-sert makes the kit for GM that I have and the las kit i bought to do a full LS2 block was from Huhn Solutions. Very good kit but takes some patience and very close attention to keep from making a simple mistake. The Time-sert kit is easier to use and more precise. Either will run you $600-700.
If you were near me in Ky I'd fix it for ya.
Since you're in Fla, I'm sure there quite a few machine shops that could do it. At least a reputable shop should have the provisions to fix an LS or LT block.
