View Poll Results: How much WHP is your car making?
200-300WHP
9
3.88%
300-350WHP
60
25.86%
350-400WHP
41
17.67%
400-450WHP
47
20.26%
450-500WHP
28
12.07%
500-550WHP
13
5.60%
550-600WHP
6
2.59%
600+WHP
28
12.07%
Voters: 232. You may not vote on this poll
How much WHP does your car have?
This is a thread I'm starting to see where everyone on this forum is at as far as HP to the wheels goes. Above you'll find the poll for how much HP you're making. Be sure to include all the modifications you have done to your car, dyno's, 1/4 mile times, and anything else you'd like to add.
I'll be first to go ahead on this. I've never taken my car to the dyno, and I have not yet been to the drag strip. But I am planning a trip in September, so I'll have those numbers soon.
For a mostly stock LS1, just two minor bolt-on's and the A4 transmission I will guess I have 280-295WHP.
YEP, got my Lid, catback, and free ram air.
Its a little late for to start dropping serious money into this car, but probably in april when it comes out of storage ill have long tubes of some sort, ls6 intake, true duals, and either a cam+tune or just a tune. I basically want a 350ish rwhp DD
618.3rwhp LSX454, lsx-ls7 heads ported shaved, arp head studs, custom grind hydraulic cam, 2in ceramic coated headers 4into1, 3in exhaust, fast 102/102, Naturally aspirated, Duspeed OTR, 25% underdriven, melling high volume oil pump, ls1 wet sump, manual 3.73's
I blew up my 5.7 and now have a Cam only 5.3 with boltons and crap, putting down 322RWHP and 308 Tourqe, through a 6spd and stock 3.42 rear. Best 1/4 time with that setup is 13.4 @ 108. It runs great on top but its hard to launch. think im gonna keep the 5.3 and put a procharger with about 12psi and a 12 bolt with 3.91 gears. That shoould be fun.
608rwhp on Cincy Speed's Dynojet 2 weeks ago. 100 degree day. Bischoff built L97 in a 09 G8 GT and ProCharger D1SC. Before rebuild car ran 11.82 @ 122mph on DRs and lots of throttle feathering.
Video of dyno run:
https://www.facebook.com/video/video...=2140891636091
Video of dyno run:
I'm in the "will be" 600+ club....expecting DEEP 600's (rumored possibility of the next digit.... ).....N/A.....engine dyno #'s in a couple weeks.
Chassis dyno early fall .
Trunion King
My car dyno'd 440-480+rwhp... on 3rd gear... dyno tuned not by me with VE/MAF fudged up and PE were jacked up AFR was 11.5-12.4-.5ish from 2K rpm to 6K rpm.
I street tuned my car... fixed the VE/MAF, added couple of timing in PE and fixed the PE AFR now reads 12.8 to 13.0ish AFR up to 6.4K rpm.
I'll redyno the car again in 4th gear 1:1 to see the results.
