Wheel spacer
Old Oct 25, 2008 | 11:13 AM
pro_performer's Avatar
Default Wheel spacer
I was thinking of getting a set of the ASA wheels and I know the sticky for the wheels says that we need the smallest spacer possible. I thought I heard that spacers were not good to use on a vehicle. Is there any truth to this?
Old Oct 25, 2008 | 12:51 PM
Corny40's Avatar
I wouldn't use them.
Old Oct 25, 2008 | 01:13 PM
neilownz's Avatar
dont see the problem if they are torqued down. might need longer studs is about it.
Old Oct 25, 2008 | 01:31 PM
The problem I heard with the spacers is that it throws the weight of the vehicle off of the hub, lugs, etc from where it is supposed to be. It doesn't sound like that is a good thing..
Old Oct 25, 2008 | 02:15 PM
Corny40's Avatar
Exactly!
Old Oct 25, 2008 | 03:02 PM
Nacho SS's Avatar
Yeah don't ASA wheels have a bad rep around here for breaking? I would only want a set of spacers for the back because the back wheels tend to tuck in more and it looks goofy.
Old Oct 26, 2008 | 11:48 AM
MonteSS8707's Avatar
There won't be a problem as long as your running a thin spacer. Your not losing much thread on the studs. Now if you run a thick spacer (3/8 inch or bigger per say) then I would run longer hardened studs. The spacer required to make ASA wheels sit flush against the rotor hub is small enough I wouldn't worry about the studs. I've been running the wheels with spacers for a while now with no ill effects. I check the lug nut torque from time to time and its dead on. Pro_Perfomer if you get ASA wheels come up to my shop and I'll put em on for you and I can get the spacers too. Just let me know.
Old Oct 26, 2008 | 01:19 PM
StealthV8's Avatar
I've off roaded with jeeps that have 37" tires and pretty big spacers. We off road hard and they havn't had a problem.
Old Oct 26, 2008 | 01:44 PM
Nacho SS's Avatar
Well those jeeps probably have stronger hubs and stronger lugs.
Old Oct 26, 2008 | 02:15 PM
StealthV8's Avatar
Probably but some are on stock axles with 35" boggers with wheels spacers. Usualy the wheel spacer isn't the week point but i guess i'm comparing apples to oranges
Old Oct 27, 2008 | 08:54 AM
2006ImpalaSS's Avatar
Why wouldn't you just get wheels that are fitted for the car.
Old Oct 27, 2008 | 05:51 PM
I did get wheels fitted for my car. Called tirerack and ordered year, make, and model. Maybe mine weren't machined correctly or ASA didn't check fitment close enough. Its a tiny, tiny gap but enough to rattle the rotor retaining torx bolts loose causing the rotors to rattle.
