Thorley Header Project Update
Old Apr 7, 2010 | 07:00 AM
  #1181
07carlocrusader's Avatar
Originally Posted by williamGT
hey yout 200-586 is the other way, mine is switched around, maybe they put it back on wrong....thanks
yeah it needs to have the numbers right side up
have a look see here:
This is upside down and that point at the bottom is exactly where the "nipple" sticks out at and as you can see their gasket is worth 2 dead flies! I think they only show this TBS like this to only just stand it up! LoL!! But that confused a lot of LS4 guys on the TBS thread!
Old Apr 7, 2010 | 07:14 AM
  #1182
williamGT's Avatar
Yeah my 200-586 is on top but looking at the car on the left is 200-586, so that means it has to be switched around that 200-586 is readable on the right side. Can't wait to go home now to switch it, 7 hours to go.
Old Apr 7, 2010 | 09:11 AM
  #1183
gulfstreamcpt's Avatar
So William,
Are we thinking it's the TBS with the whistle/exhaust noise??? I've got one as well that was mocked up from a speed shop where I used to live that had a CNC machine, so it's not one of the ones that have been talked about here on this site. So let me know when you change your's and if there's any dfference....
Old Apr 7, 2010 | 09:18 AM
  #1184
williamGT's Avatar
Originally Posted by gulfstreamcpt
So William,
I'll let you know, I hope its the tbs.
Old Apr 7, 2010 | 05:39 PM
  #1185
williamGT's Avatar
Okay so I removed the TBS and still makes the whistle, I took the car back to get the clamp tighten by the flex pipe, still whistles.....everyone tells me its normal, headers with make that noise, but does it?
Old Apr 7, 2010 | 05:55 PM
  #1186
Haulin_Ls4_GxP's Avatar
Maybe its the flexp section?
Old Apr 7, 2010 | 06:35 PM
  #1187
It can't be normal... I've got full exhaust on my T/A and there are no noises like that. Have riden in many cars that have full exhaust and no noises.... This thing is an exhaust leak somewhere and we will just have to find it....
Old Apr 7, 2010 | 07:04 PM
  #1188
Mgpeagle's Avatar
Did you guys get new header gaskets? I know they shouldn't be needed but you never know...
-Mike
Old Apr 7, 2010 | 07:12 PM
  #1189
-Mike
I know I didn't. I took the word of Chevy that these are reusable up to 5 times.... Maybe was something I shouldn't have done. Probably should have replaced them... Gonna suck if it turns out that these need to be replaced!!!!! All this work all over again!!!!! YUCK!!!!!!!!
Old Apr 7, 2010 | 07:50 PM
  #1190
williamGT's Avatar
I reused the stock gaskets, im going to cut my thick moving blanket and wrap it around the flex pipe tomorrow to see it muffles the sound, if it does im going to call DTH and send up new downpipe collector.
Old Apr 7, 2010 | 07:57 PM
  #1191
Mgpeagle's Avatar
I know some guys replaced thier gaskets and didn't get this sound. I am just throwing this out there. I do not know for sure if this is the case.
GS,
If it is the gaskets I would try to slide the old gasket out and then slide the new one in bracing the header up somehow. I would at least try this before pulling it all apart again.
-Mike
Old Apr 7, 2010 | 07:59 PM
  #1192
Mels SS's Avatar
Do you think its the weld? Mine whistles to and I replaced my gaskets
Old Apr 7, 2010 | 08:01 PM
  #1193
higsy's Avatar
I used stock gaskets as well. I've had a header leak before at the gasket and could hear a ticking noise at idle, but nothing like that here. I could see it being the flex, let me know how you make out with the blanket William. Good idea. I've got sh*t weather here so might not be able to look into till next week. Probably will run it to my mechanic.
If it's a common thing can Thorley's look into it with Buickracer's car. I haven't heard if he's even had his installed yet. Thorley will be doing the install won't they?
Old Apr 7, 2010 | 08:13 PM
  #1194
GS,
-Mike
We are gonna put the car up on a lift, one that keeps the wheels free. Gonna drive the car on the lift and see if we can hunt down the sound. Won't be for a week or so as I'm out on the road for work, but will let y'all know what we find out....
Old Apr 7, 2010 | 08:27 PM
  #1195
Mels SS's Avatar
Have you guys had any burning smell???
Old Apr 7, 2010 | 09:09 PM
  #1196
JDMC5's Avatar
I'm gonna bet it's the flex pipe. Common problem. That is IF it was installed properly.
Old Apr 7, 2010 | 09:16 PM
  #1197
AlabamaGuy's Avatar
this just in
I still love my headers.
Old Apr 7, 2010 | 10:17 PM
  #1198
It might be the flex pipe....I remember having full SLP exhaust on my 03 Monte and it sounding like it had an exhaust leak as well,...but overtime it decreased! IDK WTF happen in that situation!! LoL!! But it was the flex pipe. I wonder if its the collectors...
Old Apr 8, 2010 | 03:11 AM
  #1199
williamGT's Avatar
Well I looked at the band clamp,and its uneven (by the flex) so borrowed my friend 3/8 drive rachet and will tighten that bitch clamp in the afternoon....wish me luck.
Old Apr 8, 2010 | 03:16 AM
  #1200
williamGT's Avatar
Mel, I think the smell is normal, mine has the same smell when I installed the MF catback.
