Oil Pressure sensor replacement
Old Feb 12, 2010 | 07:59 PM
jrhartman's Avatar
Default Oil Pressure sensor replacement
I am simply looking to replace the stock oil pressure sensor. Anyone know off hand what size socket is required to remove it?
thanks
jeremy
Old Feb 13, 2010 | 03:03 AM
blakss's Avatar
did mine not to long ago and isnt that hard but i ending up taking about three hours and didnt have a socket .its bigger than standard ones.. and real PITA is you dont have space .i suggest a adjustable wrench .
Old Feb 13, 2010 | 09:40 AM
jrhartman's Avatar
it should only me a 5 minute or so job with the proper socket
Old Feb 14, 2010 | 06:44 AM
Count of Monte Carlo's Avatar
Your local parts store will have special oil pressure sensor sockets, you would be advised to obtain those.
Old Feb 24, 2010 | 10:55 PM
Kazmaniac's Avatar
Yes - the special socket is a 27mm deep well.
It should take no more than 10 minutes to change - its right on top of the engine in the front.
Old Feb 24, 2010 | 11:18 PM
bowtieboy_572's Avatar
thanks
jeremy
it may use a socket with like a lobe in it for the sending unit. kinda oblonged on 1 side.
Old Feb 24, 2010 | 11:27 PM
Kazmaniac's Avatar
No - it's a standard 27mm deep well (long) socket off the shelf part
Old Feb 25, 2010 | 05:19 PM
jrhartman's Avatar
that is exactly what I used...I just took the replacement part to sears so I could test fit it
