Time for some major upgrades Help please!
While it is in the shop being torn apart i am putting the headers on and Replacing the cat with a straight pipe. I was thinking of boring the engine out and putting forged internals on. After doing a lot of research and talking to a few companies, its not worth the 2 grand it would cost for MAYBE 20hp gains. So i scrapped that idea but i have a new plan
I am going to put a new cam in it. I am going way more aggressive. Any suggestions on the most aggressive cam i could fit in it? Keep in mind DOD was ditched a long time ago.
I am going big boys, time to see what this engine can do!
Here is the problem. We can not bore out the engine without MASSIVE cost. The aluminum block has steel sleeves. We can bore the sleeves a little bit but its not worth it. And an actual bore would be, like i said, EXTREMELY expensive.
After talking to a few people i found out a stroker kit my be the way to go instead. Here is the problem though. Our crank is shortened so no one makes that crank. People can make them but so far its like 2600 for a stroker kit, not including rods and pistons.
Unless i can find a way to do the stroker kit in an affordable way, i am just doing a cam, and forged internals.
After doing some more research, maybe grinding down a ls1 stroker kit is the way to go. Still researching it though.
If you really wanna go big, then plan for some 3.69 gears and another higher stall converter. More compression will be needed as well. I would look into some new injectors, LS6 maf and a ported polished dbw truck style tb. Your going to need tuning so you might as well swap that stuff out.
If this was my project, then I'd swap that cam for a tr 220/220 112 and a crane cams, double roller hex adjust chain, crane 1.7 gold race rockers and add the LS6 MAF, with the tb mentioned above. You would also have to use a larger air filter too, due to the LS6 MAF's larger opening. There are many LS1's making over 400whp with the tr 220 cam. YOU DONT NEED A DUAL PATTERN CAM!!!!! the LS6 cam has a very wide LSA 118-119 and over 10 degrees of extra exhaust duration@.050 with .550" lift. The tr 220 will kick its but!! Dual pattern cams are for restrictive heads and exhaust. Definitely call around and get some more info and really think about were this car spends most of it's time. If your bottom end is shot, then get a LS2 block and adapter plate, re use your crank and figure it out. Good luck and please......... don't over cam trust me!
http://www.superchevy.com/technical/...o_testing.html
And another
http://www.carcraft.com/techarticles...ine/index.html
Remember though, you will have to shift about 500rpm higher then the peak hp numbers and you will need a stall with about 1200 rpm less the peak torque rpm
http://www.vincihiperformance.com/RO...ON%20PAGE.HTML
Reason to use the Crane cams timing set
LSX SERIES ENGINE CAM RETAINER PLATE WEAR PROBLEM
We have noticed a considerable wear pattern on the front of the camshaft retainer plate, on the all of LSX series engines, including LS1, LS6, LQ4 etc trucks and on the new LS2 engines, as well. We believe this is due to improper oiling, between the plate and the timing gear. (see picture 1). This wear occurs with stock cams and after market cams as well, as it is a manufacturing defect not an aftermarket products defect. We have observed this wear on all of the LSX series engines with as little as 500 miles on them. VHP is bringing this information to our readers attention in hopes of preventing a serious engine failure. We have seen a material build up on magnetic oil pan drain plugs which, in some part, is due to the cam plate wear. We highly recommend using the Crane hex-adjust timing set on all cam installs, part number 144984-1. The bearing at the rear of the cam gear prevents most incidence of wear from re-occurring . (see picture 2). Here at VHP we have been notching the retainer plates for better oiling, to minimize this problem. (See picture 3). Upon tear down of test engines notching the plate and utilizing the Crane timing set has alleviated the problem.
I'd swap out your oil pump, for a LS6 ported pump, since you don't need the H.V anymore due to the DOD delete. H.V oil pumps costs HP.
TR 220/220 cam in mild 5.3 LOOK AT THE TORQUE CURVE! FLAT..............!!
http://performancetrucks.net/forums/...d.php?t=438267
TR 220/220 cam in another 5.3L Torque curve still FLAT!
http://www.thunderracing.com/dynogra...TB_iframe=true
TR 220/220 cam in a screaming 5.3L truck. Look at his 1/4 times. Flat torque cure AGAIN!
http://www.ls1truck.com/forums/dynod...-3-dyno-s.html
I could go on for days... and have done lots of research.
Keep in mind that our crankshaft balancer/pulley is a big time HP/TQ killer. It's extremely massive so we're always going to be handicapped! Also, these cams were installed and dyno'd in trucks with heavy driveshafts and axles with big tires, so the numbers might be a little lower then what you'd get.
I know Mix, has a bigger cam.. but it's really not needed. Again look at the tq curves. The tr 220/220 112 pulls to 6700!
Your cam specs with Cam Doctor
Duration@.050: 205* intake, 219* exhaust
Lift: 0.551 intake, 0.549 exhaust
LSA: 117.4
TR 220-112" - 220*/220* .551/.551 112 LSA
This cam opens the valves up a lot quicker then the LS6 cam. and although not recommended, you could always use 1.8 rockers. .583/.583 VS. .551/.551 It all really depends on your cyl heads flow numbers. I know the LS6 heads stop flowing more cfm, at around .550". With our smaller valves it might be a little less.
I already put down almost 320hp.....
And by 117 i mean angle, i am not trying to make it a sleeper. I want lope but i need it to idle at a light.
Almost everyone you talk to will give you different cam advice, but for your goals I'd recommend taking a look at the Stage 2 cam from Livernois Motorsports. Stage 1 will run good but won't push the envelope, and Stage 2R will have real trouble idling well.
http://www.livernoismotorsports.com/...6%3A+Camshafts
New Era also has some cams in the ballpark. These caught my eye, and since you switched to dual springs you should be able to handle the lift with no trouble.
http://www.neweraperformanceparts.co...EPSShtcamGTO|0
http://www.neweraperformanceparts.co...&PKV=SSTQGTO|0
Those are just some suggestions, and you can get a custom grind with similar numbers.
By the way, a dual grind isn't just about adding more exhaust duration to overcome a weak exhaust (and it helps more with a good exhaust), it's about the fact that the cylinder is pressurized when the exhaust valve opens. It's always been air in/power out, and there has been a lot of focus on intake lobe design (and intake runner design, porting, etc.) for that reason. But the exhaust valve does a lot of work when opening, and you need a softer lift off of the seat for the exhaust valve than you do for the intake valve. A lot of times even cams that show the same duration at 0.05" have different profiles for lower lifts.
