6speed 6T45 FWD Trans Conversion?
Old Jun 8, 2010 | 12:06 PM
  #41
TrueBlueGTO's Avatar
Originally Posted by Bryan921SS
So for the 07+ cars the trans will be a bolt on item, but what are the issues with the accessory drive??
How will the DIC be affected??
Would we lose the miles per gallon calculations etc?
I don't know. The best I can answer that is that anything that the DIC/BCM/IP reads from the ECM will be unaffected. But if it needs any data from the TCM...????.
  #42
GXP25's Avatar
Originally Posted by Panther427
Why not.... what is the gearing spreads and effective final drive ratio's on the mentioned trans. we really need a gear between 2 and 3rd. to keep the car in the power band.
I'll quote portions of my two previous posts (post 1 & post 2) on the subject (made a slight addendum to the first post's quote):
Yeah, I've felt the third gear woes as well. Good thing the other guy gave up and turned down another street.
[scratched up record]
The 6 speed (6T75) would be our "cure" (G8 transmissions for comparison):
Transmission: 6T75 | 4T65E-HD | 6L80 | TR-6060
Gear ratios:
First: 4.484 | 2.92 | 4.027 | 2.66
Second: 2.872 | 1.56 | 2.364 | 1.78
Third: 1.842 | 1 | 1.532 | 1.30
Fourth: 1.414 | 0.7 | 1.152 | 1.00
Fifth: 1 | N/A | 0.852 | 0.79
Sixth: 0.742 | N/A | 0.667 | 0.63
Reverse: 2.882 | 2.38 | 3.064 | 2.90
Final drive ratio:
3.16 | 2.93 (GXP, Super)/3.05 (CX, CXL)/3.29 (SS) | 3.27 (G8 GXP) | 3.70 (G8 GXP)
[/scratched up record]
We wouldn't feel the third gear woes until we hit fifth! That gives us third and fourth to play with.
and
SPECIFICATIONS: HYDRA-MATIC 6T75 (MY9) | 4T65E-HD (M15/MD7/MN7)
Acadia/Enclave/Outlook/Traverse | GXP/SS/Super
Engine range:
3.6L - 4.6L | 2.5L - 5.3L
Maximum engine torque:
301 lb-ft (406 Nm) | 280 lb-ft (380 Nm)
Maximum gearbox torque:
380 lb-ft (515Nm) all gears | 400 lb-ft (542 Nm)
Gear ratios:
First: 4.484 | 2.92
Third: 1.842 | 1
Fourth: 1.414 | 0.7
Fifth: 1 | N/A
Sixth: 0.742 | N/A
Final drive ratio:
Maximum shift speed/Maximum input speed:
Rev 5000 rpm | N/A
1-2 7000 rpm | 1-2 7000 rpm
2-3 7000 rpm | 2-3 6500 rpm
3-4 7000 rpm | 3-4 6000 rpm
4-5 6500 rpm | N/A
5-6 5798 rpm | N/A
Maximum validated gross vehicle weight:
2930 kg (6460 lbs) | 2903 kg (6400 lb)
Shifter Positions:
P, R, N, D, M, (DSC+/-) & L (MU/MD) | P, R, N, OD, 3, 2, 1/P, R, N, D & DSC +/-
As you can see, this transmission would be much better for the highway.
Originally Posted by AlabamaGuy
1st and 2nd both would be crazy! lol
Look carefully. 2nd gear on the 6T75 is lower than our 1st gear. So if anything, it'd be better should someone choose to start in 2nd.
The transmission should be fine for everyday driving. 1st gear included. "Racing" would be where some clever gear changes would be required. I'm not sure about everyone else, but I use TAPshift all the time.
Old Jun 8, 2010 | 12:13 PM
  #43
GXP25's Avatar
The GXP might be half of your market share. What about the rest of us that don't have tapshift or HUD?
The HUD is nothing but an extension of the DIC and radio/NAV in our vehicles; our DIC shows the gears when in "M"/TAPshift.
Old Jun 8, 2010 | 12:20 PM
  #44
EmersonHart13's Avatar
Where did you get that transmission info? I believe the GXP has the 3.29 final drive and the SS and Super have 3.06/3.05... (Or maybe I misreading your post)
I think the 2.77 final drive would be better than the 3.16 for all around driveability... As discussed on the previous page.
Yeah I would not view that as a big worry.
Old Jun 8, 2010 | 01:32 PM
  #45
GXP25's Avatar
The GXP has a 2.93 final drive ratio whereas the SS (Impala and I think Monte Carlo as well) has the much coveted 3.29. I believe that was the very same reason the Impala SS was [slightly] faster than the Grand Prix GXP in C&D's 2006 Impala SS road test.
My post and quote is wrong and will be updated.
That 2.77 final drive ratio is probably for the 6T70. The 6T75 only comes with a 3.16 final drive ratio.
I got my information from GM. I'll upload the documents again.
EDIT: Some old literature: https://ls1tech.com/forums/ls4-front...le-ratios.html
File Type: doc
File Type: doc
Old Jun 8, 2010 | 02:08 PM
  #46
Why is it that the Chevy cars seem to get better MPGs than the Pontiacs then? Hmmm... Quite strange.
I have read so much conflicting information on the internet, I don't know what to believe...
Either way on the 6 speed the 3.16 final drive is going to make first gear a smoke show.
I will read through the docs, thanks.
Old Jun 8, 2010 | 02:35 PM
  #47
DavidGXP's Avatar
GXP's have 3.29 as do the Chevys. We have sprockets, and a chain the drops the ratio to an effective gear of 2.93's. The GXP's have a taller tire I believe. Good way for GM to reduce power output to the wheels if you think about it.
Old Jun 12, 2010 | 01:05 PM
  #48
Tried like hell to finish it up Friday, but just when we thought we were in the clear, trans fluid started gushing out of the electrical harness! So we called it a day and will see where we are at Monday.
Old Jun 12, 2010 | 08:04 PM
  #49
jderou_GXP's Avatar
Transmission fluid in a manual transmission?
edit:Oohhhh, 6 speed auto. crap, this whole time I thought we were talking manual. I retract my earlier posts then.
Old Jun 12, 2010 | 08:33 PM
  #50
DavidGXP's Avatar
Is this just talk or in the works? I should probably go back through this thread.
Old Jun 12, 2010 | 10:20 PM
  #51
Haulin_Ls4_GxP's Avatar
yep he is working on it now. If I understand right the trans is in the car?
Old Jun 13, 2010 | 10:03 AM
  #52
GXP25's Avatar
No. I believe he's still working on his current project. Once that's done, he'll move over to this thread's project.
Old Jul 20, 2011 | 11:31 PM
  #53
ghetto joe's Avatar
so should i just assume this idea kinda died?
Old Jul 21, 2011 | 05:18 AM
  #54
Low91's Avatar
Seems that way. As long as we're on the subject of conversions that always seem to fall through, anybody seen a late model W-body RWD conversion? I'd love to have a LS2/T-56 combo Maybe I'll try it one day when the car starts falling apart.
Old Jul 21, 2011 | 08:42 AM
  #55
TheMonteMan's Avatar
its been done but he had a 4l60e and a ls6. it was the whole drivetrain from a corvette in a 2000 monte.
Old Jul 21, 2011 | 10:03 AM
  #56
AlabamaGuy's Avatar
The one I saw claimed to have an LS7. He was also rollin on dubs lol
Old Jul 21, 2011 | 04:26 PM
  #57
Dom87SS's Avatar
There's a guy with a 4 door GTP he turned his 3.8 straight and I want to say it's a 9 second car now.
Old Jul 22, 2011 | 07:03 PM
  #58
Sittingmongoose's Avatar
they were not able to get the tcm and ecm to talk without a LOT of funding
Old Oct 20, 2011 | 03:35 PM
  #59
Zoidborg's Avatar
I believe I can solve the computer problem, albeit only with the 6T70 based on information I have now. The good news though is that I believe the harder internals from the 6T75 can be swapped into the 6T70's case.
See my post below. This thread and the one below have gotten tantalizingly close to a solution to the LS4 question on the hardware side. I hope someone revives it, because I think I can solve the electronics side!
https://ls1tech.com/forums/ls4-perfo...l#post15530115
Old Oct 22, 2024 | 09:37 PM
  #60
Cruzen4Bruzen's Avatar
If it could be done, would you guys do it?
id do it tomorrow lol
