Old Apr 26, 2016, 01:29 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Tranmission Guides
Print Wikipost
LS4 Transmission Problem Thread (4T65-HD); Current Total Inside
Old Nov 10, 2011 | 05:52 PM
  #341
LS1 Racing's Avatar
Originally Posted by HENRYGXP
they rebuilt it. said the turbine shaft snapped in half. Car doesn't fell quite right yet. Has almost no throttle response. might be a computer issue.
These trannys are adaptive, so it might feel different until you get some miles on it and the ECM has time to "learn" your driving habits.
Let us know what you think when you get 1000 miles on it.
Old Nov 10, 2011 | 08:18 PM
  #342
HENRYGXP's Avatar
i think i need to take it to the dealer to have them flash the ecm. It feels funny. Plus the traction/stabilitrack service light is on.
Old Nov 15, 2011 | 05:18 PM
  #343
LS1 Racing's Avatar
Did you get it reflashed? Any difference?
Old Nov 16, 2011 | 08:36 AM
  #344
itchy's Avatar
Default GM Blaming Transmission Failures on "Over-Oiled" Filters
See attached ...
You have got to be kidding me.
Just out of curiosity, how many people in the Failed Transmission Club were using a CAI or K&N style drop in filter?
Old Nov 19, 2011 | 09:59 AM
  #345
ventura508's Avatar
Just had mine replaced at dealer. Thank you GM for the 5/100k warranty. First replacement, hesitation at 1800-2200 rpms shifting at 40/60/80 mph. 1.5 days later "refurbished" transmission mis-shifting into 2nd gear. At dealer for a month total, free rental
Old Nov 21, 2011 | 02:10 PM
  #346
LS1 Racing's Avatar
Originally Posted by itchy
See attached ...
Can't speak for the others here, but I added my K&N CAI after my second trans failure. I had the stock assembly in for the first 87,000 miles and two trannys!
Added you to the list!
Old Dec 7, 2011 | 05:59 AM
  #347
JDHudson's Avatar
Default Add my GXP to the list.
Just lost my tranny in the 2006 GXP. Chronic torq flutter at high speed first, then slipping all over. 110k on her but just validates all I read back when i researched buying this one. New TX from dealership seems finicky as well but only a few miles on her yet. How adaptive are we talking here? I mean a few 100 miles or a 1000? Really? Find that hard to believe.......
Old Dec 9, 2011 | 03:10 PM
  #348
LS1 Racing's Avatar
Welcome to the board!
Actually, you made it much further than most. 110k is almost acceptable when dealing with a trans!
Usually, a new trans will take around 400-500 miles to get acclimated to your driving style. If it's still doing strange things after that, then you should probably take back to the dealer.
Oh, and I added you to the list.
Old Dec 11, 2011 | 12:14 PM
  #349
Delpra14's Avatar
You can add me to the list..2006 impala ss. Rebuilt tranny at 60000 miles
Old Dec 12, 2011 | 01:10 PM
  #350
LS1 Racing's Avatar
Added you to the list.
BTW- How many miles since the rebuild?
Old Dec 12, 2011 | 01:32 PM
  #351
gxp-miller-gxp's Avatar
mine is starting to shutter when i shift at high rpms, mostly when its cold though. and makes the wierdiest noises when cold started
Old Dec 12, 2011 | 03:24 PM
  #352
LS1 Racing's Avatar
Sucks, dude.
Added you to the "dying" list.
Old Dec 14, 2011 | 09:51 PM
  #353
okie123's Avatar
rebuilt at 78,000. Currently still going now at 110,000.
Old Dec 16, 2011 | 08:52 PM
  #354
4doorSS's Avatar
mine went out around 72k and you already have me on the list and ive got 98k on it now and every now and again it likes to hang in third before shifting to overdrive ill tell you one thing ill get rid of it before i drop another 3 grand
Old Dec 20, 2011 | 02:21 PM
  #355
LS1 Racing's Avatar
Added okie123 and EmersonHart13 to the list.
Old Dec 21, 2011 | 03:09 PM
  #356
ssilver06''s Avatar
Count me in for Transmission rebuild number 2. Didn't replace all the parts they needed to te first time (under warranty). So they had to rebuild the rest of it 10k later. Rebuild 1: 64000 mi., rebuild 2: 76000. Hopefully all problems have been sorted out. Also, have been running k&n cold air since around 40k. Dealer never said anything about it.
Old Dec 22, 2011 | 02:06 AM
  #357
mikee21089's Avatar
Has anyone found out what is causing the issue with the transmission?? is it computer related, valve body related?? What is the actual reason for all these transmission problems.
Old Dec 22, 2011 | 08:47 AM
  #358
EmersonHart13's Avatar
There are quite a few threads discussing this but this is what I have gathered.
Torque converter blows up. There is a relief valve sold by Sonnex that fixes the problem, but the entire trans needs to be taken apart to remove it. The core issue is this trans is rated for less power than the LS4 produces and GM tried to use electronics to manage it. Well as we can see it didn't work.
It doesn't matter how you drive your car (minus beating on it), it will eventually happen. Some of us got better transmissions than others. Hwy miles tend to help prolong it.
Old Dec 22, 2011 | 01:09 PM
  #359
LS1 Racing's Avatar
Well said...And to that, I'll add that GM cheapened out on certain parts like seals, which shrink with age and miles, causing some of the problems we see.
Old Dec 23, 2011 | 06:03 AM
  #360
Park ave. fan's Avatar
What the **** is up with GM? I just went through hell with a blown headgasket on a turdstar in my (no longer owned by me)deville. I found a 2008 lacrosse super with a small block and I thought "good, a real engine", but now I see it will be burning out its tranny soon! Great!!
What a ******* shame, Gm used to build bullet proof drivetrains.
Oh well.....
Anyway, I have 33600 miles on my super and so far(knocking on wood) its doing fine. After reading the horrors of this thread, I WILL be buying the GM extended warrenty before the factory one runs out!!
