Couple of vids from my run at the track last night
14.20 and a 14.36 run on the vids. Got 5 runs in, all around the same time. I was hoping for a high/mid 13s as the weather was nice and cold, but couldn't get it
http://www.youtube.com/watch?v=EXaJqj-0U2Q
http://www.youtube.com/watch?v=linLuDfnUhU
Let me know what you think and any advice.
with practice you should be able to cut low 2.0x 60's on stockers. It seems to me that your car is lacking some. doesn't seem to pull hard up top???? how many miles on it? my GXP (granted it was 3 months old at the time) would make the shift to 3rd (101mph) and trap 102+ all day long in cold weather and still trap 100+ in warm weather. Not sure of your trap speed but it didn't seem to be over 100?
if you get the 60' down some you still will only be a 14.0 car. Something in your combo is hurting you. you need to go back to stock/ish and see what the deal is.. I would try a Stock tune first. Get it dynotuned and see what the tuner sees.. what was the DA??
He's ran in the 13's before if I remember correctly. And I had the same setup as him and ran 13.5 @ 103 in a decent DA. I'd go with DR's, maybe time for a trans fluid change and shift kit.
first off great vids mabey in my opp adj the shift points alittle you seem to shift at the stock shift point in the superchip you can do stock plus 2 or 3 hundred it makes a big difference and gets rid of the second gear bog well it seem to in my car but all the same good runs i wish my car would hook at two grand
I have the shift points at 300 rpm for first and I believe 700 on the second to third shift.
I'm really considering getting smaller and lightweight wheels for the front, that should help out.
