Minor work today
Old Feb 17, 2011 | 03:25 PM
Sadden's Avatar
Default Minor work today
Did an oil change today
Found some scaly **** in my oil
New filter
Some super shitty oil
half a can of seafoam
Gonna run it for a week and repeat
One more week of that
Then im adding my good synthetic
Also tonight im doing my Transgo SK
Anything i should know?
What are you guys finding with with the diffs in these cars? Are they weak?
I really want to make this trans bulletproof before anything starts to fail.
Old Feb 17, 2011 | 03:27 PM
2005gxp's Avatar
get a trans cooler on there also. cooler t-stat helps too.
Old Feb 17, 2011 | 03:47 PM
BLKGXP's Avatar
The best thing you can do to make our tranny rock solid is pray to your holy figure & buy a homeless guy a 40 or two... Good luck!
Signed,
Proud owner of a new GM tranny
Old Feb 17, 2011 | 03:51 PM
Sadden's Avatar
Wait put a Tstat on the tranny cooler?
Old Feb 17, 2011 | 03:53 PM
DavidGXP's Avatar
I run a qt of trans fluid in my engine oil a week before I change my oil and filter.
Transgo shift kit install tip.
BE PREPARED FOR A BIG *** MESS!
Old Feb 17, 2011 | 03:54 PM
Bryan921SS's Avatar
A cooler t-stat will do you no good...but a trans cooler will help.
The only way to make these transmissions stronger is to rebuild them with better parts.
Old Feb 17, 2011 | 03:55 PM
RA4926's Avatar
The logic behind a cooler Tstat is a cooler thermostat in the cooling system keeps the radiator cooler and in turn keeps the transmission fluid cooler, since it is cooled in a chamber in the radiator.
Old Feb 17, 2011 | 04:45 PM
Ill_Born_ss's Avatar
Tranny cooler is a good idea, most good ones are thermostaticly controled for oil flow to allow quicker warm up and to start functioning at or about 160*
As for the EC thermostat, WARNING leave it alone! Your car is computer controlled and if you were to monitor it you would see that it does not go into closed loop until 88*c/ 190*f. THIS A VERY IMPORTANT FEATURE
Old Feb 17, 2011 | 05:06 PM
Sadden's Avatar
Well down the road i want to take a weekend and fully rebuild it.
My question
What hard parts?
Old Feb 17, 2011 | 05:19 PM
2007SSImpala's Avatar
I have read terrible things about transgo kits. Get a thrasher kit or a zzp kit.
Old Feb 17, 2011 | 05:26 PM
Sadden's Avatar
All the Hbody guys say they cant even feel the ZZP kit.
Old Feb 17, 2011 | 05:39 PM
DavidGXP's Avatar
[QUOTE=2007SSImpala;14518494]I have read terrible things about transgo kits.QUOTE]
Old Feb 17, 2011 | 05:40 PM
DavidGXP's Avatar
Old Feb 17, 2011 | 05:44 PM
2005gxp's Avatar
i like my cartuning shiftkit, works really well.
Old Feb 17, 2011 | 06:08 PM
LS1 Racing's Avatar
Call Dave @ TEP and buy a trans or at least a valve body, seal kit, and Sonnax converter valve.
Thee's simply no such thing as a bulletproof stock trans in an LS4 car, not even with a shift kit and cooler.
Your comment would be the first I've heard about it, and you really didn't say anything other than you've "read terrible things."
Please elaborate, if you wish to be taken seriously.
Old Feb 17, 2011 | 06:49 PM
Not hard to find info on them. Google it.
Old Feb 17, 2011 | 07:16 PM
Hawkins04's Avatar
Just curious but why do you dun trans fluid in there? As for the transgo kit I haven't read anything bad about them
Old Feb 17, 2011 | 07:38 PM
RedHotG8's Avatar
Putting transmission fluid in the oil is a good way to ruin the motor. Modern day oil has detergents that clean the motor, so there's no need to anything but oil in it.
Old Feb 18, 2011 | 12:55 AM
Haulin_Ls4_GxP's Avatar
How is transmission fluid going to ruin a motor? Its oil just not a thick as motor oil? Adding a half a qt. or so isn't going to do anything by clean the engine. Transmission fluid has more detergents than motor oil. I've seen diesel engines run with nothing but transmission fluid for over 1000 miles and it didn't do any damage.
Old Feb 18, 2011 | 07:26 AM
Back in the day , when transmission oil was basically mineral oil/whale oil this practice was and acceptable means of upper cylinder cleaning. With todays mostly man made tranny fluids it is not really a safe method of internal cleaning. The most common practice today is to change your gasoline engine oil using diesel engine motor oil for 500- 1000 miles and then returning to conventional gasoline approved motor oils. This practice should be done no more than one time in 50,000 miles. As for deisel engines the practice is mostly use 1-2 cups of deisel fuel in oil and idle/high idle for no more than 15 minuites, drain and refill as manufactures recommendations. (there is also a warning with this method, do not use engine under load conditions... may turn a main bearing)
