Oil consumption: GM's official fix for the LS4
#11-06-01-007: Engine Oil Consumption with Active Fuel Management (AFM) (Install Oil Pan Gasket and Clean Carbon from Cylinder) - (Nov 22, 2011)
Subject: Engine Oil Consumption with Active Fuel Management (AFM) (Install Oil Pan Gasket and Clean Carbon from Cylinder)
Models: 2008-2009 Buick LaCrosse/Allure
2006-2007 Chevrolet Monte Carlo
2006-2009 Chevrolet Impala SS
2005-2008 Pontiac Grand Prix GXP
Equipped with V8 Engine RPO LS4
Condition
Some customers may comment about engine oil consumption of vehicles with higher mileage (approximately 48,000 to 64,000 km (30,000 to 40,000 mi). Verify that the induction system is assembled correctly and that there is no evidence that the engine has been ingesting dirty air due to a mis-assembled induction system. Also verify that the PCV system is functioning properly. If diagnostic procedures indicate that oil consumption is piston/piston ring related, verify that oil consumption is greater than 0.946 L (1 qt) in 3,200 km (2000 mi). If these conditions are met and oil consumption is greater than 0.946 L (1 qt) in 3,200 km (2000 mi), perform the service indicated in this bulletin.
Cause
This condition may be caused by oil spray that is discharged from the AFM pressure relief valve within the crankcase. Under most driving conditions and drive cycles, the discharged oil does not cause a problem. Under certain drive cycles (extended high engine speed operation), in combination with parts at the high end of their tolerance specification, the oil spray quantity may be more than usual, resulting in excessive deposit formation in the piston ring grooves, causing increased oil consumption.
To correct this condition, perform the piston cleaning procedure as described in this document, and install the new oil pan gasket per the procedure outlined in this document. Monitor oil consumption after this repair to ensure oil consumption has improved to acceptable levels.
If this repair does not correct the condition, it may be necessary to replace the piston assemblies (piston and rings) with new parts.
Correction
A new oil pan gasket has been released. Technicians should replace the oil pan gasket with GM P/N 12643081. This oil pan gasket has the AFM shield incorporated into the gasket. Refer to SI for Oil Pan Gasket Replacement.
If this repair does not correct the condition, it may be necessary to replace all of the piston assemblies (piston and rings) with new parts. Refer to SI for repair procedure.
Important: It is critical in this cleaning process that the engine/fuel injector cleaner remain in the cylinders for a minimum of 2.5 hours to fully clean the components. The cleaner solution must be removed before a maximum of three hours.
1. Verify the oil consumption concern following Corporate Bulletin Number 01-06-01-011G. If oil consumption is found, continue on with this bulletin.
2. Remove the spark plugs and ensure that none of the pistons are at top dead center (TDC).
3. Clean the pistons by putting 118-147 ml (4-5 oz) of Upper Engine and Fuel Injector Cleaner, GM P/N 88861802 (in Canada, use 88861804), in each cylinder. Allow the material to soak for at least 2.5-3.0 hours, but no more than three hours and then remove the cleaner. A suggested method of removing the cleaner is cranking engine over. Make sure to unplug the ignition coils and fuel injector before cranking the engine over. Also make sure that the painted surfaces are covered so no damage is done.
4. Remove the oil pan. Refer to Oil Pan Replacement in SI.
Important: Ensure that the engine cleaner is thoroughly removed before reinstalling the spark plugs. Failure to do so may result in a hydro-lock condition.
5. Reinstall the spark plugs. Replace the spark plugs if necessary due to full of carbon. Refer to the parts catalog.
6. Reinstall the oil pan. Refer to the Oil Pan Installation procedure in SI. Replace the oil pan gasket.
7. Re-evaluate the oil consumption. Document on the repair order. If the oil consumption is still greater than 0.946 L (1 qt) in 3,200 km (2000 mi), replacement of the pistons and rings will be required.
Important: Some minor scratches may be noticed on the cylinder walls during piston and ring replacement. If the scratch cannot be felt when running your finger nail over it, the scratch is considered normal wear and the block or engine should not be replaced.
Note: It is not necessary to hone or deglaze the cylinder walls. Honing may induce unnecessary cylinder wall and / or piston ring damage if it is done incorrectly and/or not cleaned thoroughly. Cylinder walls should cleaned thoroughly with brake cleaner before installation of the new pistons and rings. Numerous engines replaced for oil consumption have been inspected. The cross hatch has been consistently good and is in specification. As a result, is should not be necessary to measure the cylinders if they pass the visual inspection.
Parts Information
Part Number: 12643081 Oil Pan Gasket
Part Number: 88861802 (in Canada, use 88861804) CLEANER, F/INJR 16 OZ LIQUID POUR (Upper Engine and Fuel Injector Cleaner)
Condition
Cause
Correction
Parts Information
Service Information
Home Publications Number Search Bulletin Search Help
2005 Pontiac Grand Prix | Grand Prix (VIN W) Service Manual | Engine | Engine Controls - 5.3L | Repair Instructions | Document ID: 1461510
Oil Pan Replacement
Removal Procedure
Object Number: 1655027 Size: SH
Click here for detailed picture of above image.
Remove the engine frame. Refer to Frame Replacement .
Drain the engine oil and remove the engine oil filter.
Reinstall the drain plug and oil filter until snug.
Remove the transaxle converter cover bolt/stud and cover.
Object Number: 1551872 Size: SH
Disconnect the oil level sensor electrical connector.
Remove engine harness retainer from the front of oil pan.
Object Number: 1551874 Size: SH
Position the drive belt tensioner aside in order to access the oil pan bolt. Refer to Drive Belt Tensioner Replacement - Accessory .
Remove the oil pan bolts.
Remove the oil pan.
Object Number: 384699 Size: SH
Important: DO NOT allow foreign material to enter the oil passages of the oil pan, cap or cover the openings as required.
Drill (3) out the oil pan gasket retaining rivets (2), if required.
Remove the gasket (1) from the pan.
Discard the gasket and rivets.
Clean and inspect the engine oil pan. Refer to Oil Pan Cleaning and Inspection .
Installation Procedure
Important:
• The alignment of the structural oil pan is critical. The rear bolt hole locations of the oil pan provide mounting points for the transmission housing. To ensure the rigidity of the powertrain and correct transmission alignment, it is important that the rear of the block and the rear of the oil pan are flush, or even. The rear of the oil pan must NEVER protrude beyond the engine block and transmission housing plane.
• Do NOT reuse the oil pan gasket.
• It is NOT necessary to rivet the NEW gasket to the oil pan.
Object Number: 1551873 Size: SH
Apply a 5 mm (0.20 in) bead of sealant , or equivalent 20 mm (0.80 in) long to the engine block. Apply the sealant directly onto the tabs of the front/rear cover gasket that protrudes into the oil pan surface. Refer to Adhesives, Fluids, Lubricants, and Sealers for the correct part number.
Important: Be sure to align the oil gallery passages in the oil pan and engine block properly with the oil pan gasket.
Pre-assemble the oil pan gasket to the pan.
2.1. Install the gasket onto the pan.
2.2. Install the oil pan bolts to the pan and through the gasket.
Notice: Refer to Fastener Notice in the Preface section.
Install the oil pan, gasket, and bolts to the engine block.
Tighten
• Tighten the oil pan and oil pan-to-front cover bolts to 25 N·m (18 lb ft).
• Tighten the oil pan-to-rear cover bolts to 12 N·m (106 lb in).
• Tighten the transmission housing, converter cover, and transmission bolts/stud to 50 N·m (37 lb ft).
Install the drive belt tensioner. Refer to Drive Belt Tensioner Replacement - Accessory .
Install engine harness to front of oil pan.
Connect the oil level sensor electrical connector.
Install the transaxle converter cover and bolt/stud.
Tighten
Tighten the bolt/stud to 12 N·m (106 lb in).
Install new engine oil and a new oil filter. Refer to Engine Oil and Oil Filter Replacement .
Install the engine frame. Refer to Frame Replacement .
© 2011 General Motors Corporation. All rights reserved.
Oil Pan Replacement
Removal Procedure
Remove the oil pan.
Important:
Tighten
Tighten
Sounds to me like it isn't a recall where they fix it for free. If you're under warranty and you're having the issue it should be free, but if not, it'll come out of your pocket. To me, it's cheaper and easier to just carry a quart of 5w-30 in the trunk in case you need to top the oil up on a long trip.
The following users liked this post:
The70judge (03-04-2020)
I already do that. Sounds to me the easier fix is to tune DOD out. I'm not taking half the car apart to put this shield in
So what do you do if you have a 07 MCSS unable to turn off DOD. I emailed Diablosport and they no answer for me at this time or the future. So who are people using on the 07 MCSS would like a handheld unit to turn off DOD. I am taking it in for the TSB oil consumption stil have drive train warranty till june of 2012.
