Good wearing tires?
The Pilot Sports sound like a good choice albeit a little pricey. Very happy with the Michelins on our last GP though. You get what you pay for sometimes.
This is what we threw on my GF's GXP, they were pretty good in snow surprisingly for only being an all season. They seem to not be wearing very fast.
http://www.discounttiredirect.com/di...%2FPerformance
Eagles on the rear but I don't think they make a matching tire in the 255/45 series. At least the car is not cupping the rear tires like all of our other FWD Pontiacs have done.
http://www.discounttiredirect.com/di...w=false&cs=255
http://www.discounttire.com/dtcs/fin...Form&rc=ILCINT
I am on the stock rears with -2.0 camber in back and they still have at least 60% tread left. I run winter tires so Im guesstimating they have roughly 50K on them. Only reason Im getting rid of them is because they are 7 year old tires and they are dry rotting. Im on the second set of fronts and I replaced them with the OE tires running -1.7 camber in front. My wife drives the car and shes a lead foot. Im replacing the fronts because they have about 20% left on them. I ended up getting the whole set OTD for $760.00 I believe it cost me $650 to replace the 2 fronts with the OE tires! They should be in today and if you like I can post my opinion on them tomorrow when I have them installed.
I would look at these if you need AS tires:
My brother in-law swears by Yokohama he ran them on his Bimmer and went through two sets. I had Yoko's on an SE-R and they were good in the snow and lasted awhile.
I would suggest Continental Extreme Contact DSW's my friend runs them on the front of his GXP but with less than 20k on them the "s" wore off so they aren't good for snow anymore. I run them on my GTP and they are awsome but I rotate them every oil change and I get about 30k a set on them and im on the second set since I started using them.
My Toyo Proxes 4's lasted 34k of hard driving and rode unbelieveibly smooth and the grip was awesome. I'm riding on snow's and stocks right now, waiting for my new 19's and getting the new Toyo 1 sport front and rear. Can't wait.
Kumho Ecsta LX Platinum
Matching set priced at tirerack
DO not get the Goodyear Eagle F1s. I had a set that lasted 10K and they replaced them for free under their milage warrany and the second set only lasted 10K as well and the alignment on the car was right on every time.
Both the RE50 and Pole position had very good handling. The tread life sucked and that was with conservative driving and proper alignment. The Poles were better then the RE50. The 760s upfront had a pretty good tread life but I was still not fully happy with them.
I love my LX Platinum. After reading alot of reviews from other GXP owners I was set on giving them a try. They give up some dry weather traction under very spirited driving but with the Traction Control and Stability Control on with the Active Handling you wont really notice it. They are quieter then any of the Bridgstones. And for me in the south with all the FL and GA heavy rains I wanted better wet traction. And the LX Platinum really deliver it better then any of the Bridgestones... Would I recommend them for the track, NO. But I can honestly say that you wont be finding yourself needing anything more on the street. Expectantly when you see how long the tread lasts.
You could rotate staggered tires if you go with an asymmetric tire...
I installed 255s in the front and 235s in the rear and it was like a different car. Tire: Michelin Pilot Sport A/S plus.
imo best tire to replace stock, LONG tread wear, great traction in wet and dry, comfort and noise levels are excellent
once my KDRs wear off i'm getting another two 255/45/18 for the rears as im running 18x8 all around, here is the tirerack page for specs:
http://www.tirerack.com/tires/tires....(W-Speed+Rated)
