06 Monte Carlo - Rear Speaker Adapter?
Old 10-21-2012, 02:35 PM
2006 Silver Monte SS's Avatar
Default 06 Monte Carlo - Rear Speaker Adapter?
I have a 2006 Monte Carlo SS with AMP under the rear shelf.
I ordered front & rear speakers and have seen the adapters for the front 2-wire connectors, but is there an adapter available for the rear 4-wire speaker connectors?
I also have a 4-channel Alpine amp that I would install if I had an idea of how to bypass the factory amp without running new speaker wires or changing the head unit.
Any help would be greatly appreciated
Old 10-21-2012, 03:39 PM
lVloses's Avatar
What you have to do is get rid of the crossover on the speakers and soder the wires individually on the woofer and tweeter of the 6x9s.
Old 10-21-2012, 05:34 PM
Looking to keep the factory head unit, but replace the speakers and bypass the amp so I can use my own 4-channel amp.
I just ordered this to convert the factory signals to clean, separate pre-amp outputs:
Old 10-21-2012, 10:47 PM
roadrash187's Avatar
What model amp do you have? Might have hi level inputs on it already. If it does the Audio control you bought won't be needed.
Old 10-21-2012, 11:35 PM
I'm using an older Alpine amp with only RCA inputs.
Does anyone have the wiring diagram for the input connector on the factory amp?
Old 10-22-2012, 10:52 AM
El Cid's Avatar
Pin
1 (Tan) = Left Front Low Level Audio Signal (+)
2 (Light Green) = Right Front Low Level Audio Signal (+)
3 (Brown/White) = Left Rear Low Level Audio Signal (+)
4 (Dark Blue) = Right Rear Low Level Audio Signal (+)
5–8 Not Used
9 (Dark Green) = Left Front Low Level Audio Signal (−)
10 (Light Green/Black) = Right Front Low Level Audio Signal (−)
11 (Brown) = Left Rear Low Level Audio Signal (−)
12 (Tan) = Right Rear Low Level Audio Signal (−)
13–16 Not Used
Old 10-22-2012, 11:50 AM
Sweet...Thank you Sir! That is exactly what I needed (but are you sure those are low level?). Now I can splice in the LC6i and add my amp & speakers...and as long as I'm doing this, I might as well add my sub box with two Rockford 12" and other alpine amp to drive them
To everyone that says you can't replace the rear speakers and keep the stock head unit...
Old 10-22-2012, 12:57 PM
lVloses's Avatar
It's not that, it's the rear speakers and the amp. I believe the Monsoon amp is 2ohm so you need 2ohm 6x9s to replace your stock ones with and those aren't the easiest to find iirc. I ran aftermarket 6x9s for almost a year on my stock head unit before I upgraded to my DNX9990HD.
Old 10-23-2012, 01:38 PM
El Cid's Avatar
I have not measured the voltage on the input side.
I read the instructions for the LC6i, and the way that I understand it, if it doesn't work on the input side due to voltage (low) issues, you could pick up the signal on the output side of the factory amp.
Old 10-23-2012, 01:42 PM
El Cid's Avatar
Monte Carlos (and Impalas) do not use a Monsoon amp, it is made by Panasonic. The speakers are bi-amplified. Low frequency is 2 ohm impedance, highs 4 ohm.
Old 10-23-2012, 01:47 PM
lVloses's Avatar
But then again it's not the head unit that's the problem, it's the amp that causes issues.
Old 10-23-2012, 05:00 PM
You are both correct. No need to argue...
So, this factory setup is not unlike a typical system (4 ohm front, 4 ohm rear + 2 ohm sub), they just have it wired so you can't simply do a plug & play setup.
I was trying to keep the install as simple as possible, but since I already have 2 Alpine amps and 2 Rockford 12"s in a box, I am going to do the full deal with new wires and all. I just wanted to keep the factory HU to keep the inside looking 100% factory...plus it does everything I need it to for now.
One more question - would you mount the 2 amps & LC6i on the sub box or on one of the fold down seatbacks for easy access to adjustments?
Old 10-24-2012, 04:25 PM
El Cid's Avatar
I don't think anyone is arguing; I'm just offering clarification to those that read these posts and may not know that the Grand Prixs and the Monte Carlo/ Impala do not have the same audio systems.
The premium amplifier mounted in the trunk of a Monte Carlo SS/ Impala SS is basically a multi-channel amplifier, with individual channels for low and high-frequencies running out to the speakers. Crossover duties are handled inside the amplifier, not outboard at the speaker. Any aftermarket speaker that can be bi-amplified can be used with our wiring and amplifier configuration.
Mounting the LC6i and amplifiers to the enclosure would be fine IMO.
Quick Reply: 06 Monte Carlo - Rear Speaker Adapter?
