rear end issue?
rear end issue?
I cant stand this. Out of nowhere my car has a shimmy when i slow down. Not my brakes bc it doea it even when im just off the throttle at lower speeds. I can see in my rear view mirror my car shimmying side to side, and it makes me move side to side in my seat. Wtf is it?!
I havent tried that yet bc i live in ny and its 10 degrees and snowing everyday haha. Which sucks bc i cant check, the garage isnt car accessible. I noticed it the first time i slowed down rivhr afyer i picked my car up from a shop after getting tranny work done. Car wasnt doing this when i dropped it off...but i dont see why they woulda messed with the rear end doing tranny work. They did tell me i had a loose tie rod in the front, but i believe they fixed that problem so idk if that could be it? Plus a shimmy that u feel in ur seat and not the steeri g wheel is usually a rear end symptom right?
But wouldnt i feel that in my front end/steering wheel? I dont feel anything in the wheel. For what its worth, i also noticed the other day my steering wheel is suddenly of centered when driving which idk y either...
No the outer joints you would feel and hear in the steering but the inner joints give a square tire feeling and the worse they are the worse the vibration... seat of your pants/ whole car.
As for the steering they should of centered it and that must be done visually and with a scanner or the computers will see a YAW indication as you are going straight and it will throw the traction and stability control off.
Was an alignment done after the tie rod was repaired/tightened. Bad alignment will make your vehicle squirrely. I had a mustang that I replaced the rack on and every bump I hit afterward made opposite corners bounce and when it did, it pulled to different sides depending on where in the bounce I was. If they didn't check, have someone check it.
