teardown has begun!
Seems like the electric option is really the true alternative
Making the pwm controller is the only hump in the road
heres the moog spherical CAB's pressed into the new control arms, and compared against the old style
here you can see how remanufactured arms reuse the old cages, two different style of CAB cage on both arms. Doesnt me they are bad, just not held to any sort of precision standard, even on the OEM parts. Ill be throwing these up for sale as they are perfectly fine for anyone who wants to replace CAB's with oem style.
MEVOTECH CMS501061
MOOG K200787 for the spherical control arm bushings, they would work on any of the arms.
You want CMS20329 and CMS20328 if you want the one designed for the 24mm bar. That would require the other style end link too.
