teardown has begun!
Old Jul 25, 2015 | 09:45 PM
  #461
rottonj's Avatar
I think this should be the GMPP bar, if so its actually a little cheaper than the Dorman bar. so many damn part numbers its confusing lol.
http://www.ebay.com/itm/271878206776?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old Jul 25, 2015 | 10:15 PM
  #462
spawne32's Avatar
What were the two size bars that came from the factory, i saw 20 and 24mm listed, didnt know 34mm was a factory option.
Old Jul 25, 2015 | 10:28 PM
  #463
rottonj's Avatar
I dont think its factory on our cars(Grand Prix), but I believe the police package Impala has it. Lots of confusing info everywhere.
This is the kit.
http://www.gmpartsdirect.com/results...umber=12498643
Old Jul 25, 2015 | 10:29 PM
  #464
91parkave's Avatar
Moderator
All things wbody are interchangeable. The red was the gmpp I got off a 9c1 police impala. The Dorman unit like I said before is a solid unit but you have to use 97 03 control arms and end links as stated before. I know you hate Dorman but this is money well spent. As for what you linked with no size I wouldn't order unless I knew for sure.
Old Jul 25, 2015 | 10:37 PM
  #465
rottonj's Avatar
Thanks. That red bar looks much smaller in the pic, the gmmp bar should be a little bigger. I will check them both out
Old Jul 25, 2015 | 10:46 PM
  #466
spawne32's Avatar
good god, had i known it was that ****** cheap from GM i would have bought that
Old Jul 25, 2015 | 10:53 PM
  #467
rottonj's Avatar
Then your whole parts list would have had to change also. I've been planning this for awhile, just keep watching prices and looking for deals. I have had the sway bar bushings and end links for awhile, that's why I haven't jumped on the GMpartsdirect package.
Old Jul 25, 2015 | 10:55 PM
  #468
spawne32's Avatar
well like i said, i only race in straight lines, this would be a total waste lol
Old Jul 25, 2015 | 11:01 PM
  #469
rottonj's Avatar
Yea, I'm not about the quarter mile runs. I love high speed and handling.
Old Jul 25, 2015 | 11:24 PM
  #470
rottonj's Avatar
I found this also, says its 34mm. Who the **** knows. Too many part numbers. i guess I will see when I get it lol.
http://parts.nalleygmc.com/products/.../25861196.html
Old Jul 27, 2015 | 01:37 PM
  #471
spawne32's Avatar
new factory fit 3rd generation w body cooler from an impala ss
Old Jul 27, 2015 | 02:01 PM
  #472
91parkave's Avatar
Moderator
I would've went for a bigger cooler being canned and mild stall. Not to mention it won't catch the most airflow. But regardless the quick fitting can take out and substitute with a 3/8th to -6 fitting so you can make more reliable connections
Old Jul 27, 2015 | 02:18 PM
  #473
spawne32's Avatar
well, given that its almost identical in size the hayden 679 cooler i just sold, and the fact that the OEM fittings and lines are just as reliable as AN lines, I dont feel as though this is going to be a problem. If it was good enough for the impala police pursuit car, then im sure its good enough for my DD.
Old Jul 27, 2015 | 02:37 PM
  #474
91parkave's Avatar
Moderator
Police cars also never came canned and stalled. Different ball game. I have that same one I used from a police package impala. Did good but doesn't perform nearly the same as the police package oil cooler ended up. Drove from from Arizona to Georgia with the highest being 172.. mostly 167 the whole way. AN fittings easily trump quick connect cap that's prone to leaks.
Old Jul 27, 2015 | 04:42 PM
  #475
spawne32's Avatar
I am not canned and stalled, cammed maybe, but not stalled. This is a factory replacement converter from TEP, not a stall converter. The highest I get is in the 220's, if it dropped it 20 degrees, id be happy. This setup is also an aftercooler as well, which is exactly the way I wanted it.
Old Jul 27, 2015 | 05:29 PM
  #476
91parkave's Avatar
Moderator
You should be going for alot lower than 200 dex 6 is a synthetic if you want that Trans to last and not burn it up get a bigger cooler and get rid of the factory crap
Old Jul 27, 2015 | 08:25 PM
  #477
spawne32's Avatar
got it partially installed tonight, as i suspected that damn top outlet runs smack into something. So gonna have to figure out some hard line routing to make that turn up and over the AC condenser around the radiator to the existing line. Gonna enlist a buddy of mine who does this kinda stuff for a living to design a semi hard line to make that turn and go into the trans. Very happy with the mounting of the cooler right now, just have it secured at the bottom with zip ties at the moment while i continue to mock up the lines, had to make a minor modification to the torque mount bracket and tap the hole right below it for a M8 bolt.
Old Jul 27, 2015 | 08:31 PM
  #478
rottonj's Avatar
Good looking cooler. Nice factory look.
Old Jul 27, 2015 | 09:15 PM
  #479
spawne32's Avatar
really annoys me that the factory 4t65e lines are 150 dollars more then the ones for the newer transmissions -_-
Old Jul 27, 2015 | 09:22 PM
  #480
spawne32's Avatar
almost my dogbone bushing is destroyed lol the square one in the middle spins completely inside the housing
