teardown has begun!
new timing set, GMPP heavy duty chain, 3 bolt sprocket with the 4x pickup for the cam position sensor, and new automatic tensioner.
LS7 lifters have been soaking for quite a while now (bout a week) and doing the 1st step on the head torque sequence after installing lifters and trays and head gaskets.
with the heads fully torqued (oh god my arms) using a torque angle meter, 22 ft lbs, + 90 degrees + 70 degrees, leaving the rocker arms sitting there for the night and tomorrow ill work on checking pushrod length. Once i have the right pushrods in, ill degree the cam.
My suggestion to you would be to continue grinding both sides with some roloc discs. Try your best to get 1/2" on opposing sides of the crack clean, then scrub it down with some acetone. See if you can't find a general welder instead of a picky machinist to patch that up.
Too bad your not closer, I could hammer that out.
cheap porous aluminum, the grease and grime sinks into it and you can never get a clean spot. my neighbor just cracked a valve cover and oil pan on his mazda 6 the other day trying to reassemble the engine, it was so brittle the torque of the bolts make it crack.
