teardown has begun!
Question on pulling the engine out, is the set up on these LS4 cars similar to the f-body?
could these drop from the bottom with the cradle?
Lets see the progress, and the minor modification.
I'm also upgrading brakes and adding an in-line transmission fluid cooler.
I'm looking for a decent cam for the upgrade with close to stock LSA, maybe one close the hot cam specs but with 116 or 117 LSA, I don't want the lopy sound, car gets enough attention as it is....
Would the LS6 cam be a good upgrade?
As far as porting the heads go, do not, i repeat, do not attempt to hand port them yourself. This is one car I would just not recommend that. Port velocity is going to be your critical feature here that is important to maintain, its not just a matter of hogging it out for max CFM. Go with a reputable CNC company, and don't go for just the largest port they offer, those ports are designed for high compression big cam cars. For instance you can get away with advanced inductions 218cc package and pickup some decent gains without over porting the intake side, but this will all rely heavily on what intake manifold you choose. An LS6 intake conversion is a must on these car's, my only reason for using the stock one right now is that i'm out of money for the budget for this car at the moment.
