powered sub
Old Jan 25, 2016 | 10:57 AM
blkchevyz's Avatar
Default powered sub
thinking im going to hang on to this car for awhile so i figure its time to make some changes.
is it fairly simple to add a sub to the monsoon system?
Old Jan 28, 2016 | 02:04 PM
LeadfootDuramax's Avatar
I think so. I used high level inputs from the rear speakers. As long as the powered sub or amp you use can take them it's simple. If not, you can buy an adapter to convert the signal. Otherwise, it's just the usual power, ground, remote wires.
Old Jan 29, 2016 | 05:03 PM
blkchevyz's Avatar
cool thanks.
Old Feb 3, 2016 | 09:19 PM
08 pimpala ss's Avatar
Check out the jl powered 8 in box I have installed a bunch and there are very impressive sounds more like a 12. You can grab high level right out of the monsoon amp from the sub out but for better sound you can grab front door woofers signal because it has a better crossover slop
Old Feb 4, 2016 | 11:42 AM
blkchevyz's Avatar
i actually already order this.
http://www.crutchfield.com/p_575P300...10.html?tp=114
got a better price on it though.
amps right under by the rear speakers correct? not sure i want to go through the trouble of running wire through the door if pulling it from the rear still sounds good.
Old Feb 22, 2016 | 08:37 AM
blkchevyz's Avatar
what do you guys use for the power on signal? i found something on here about using the sunroof, and used the wire they specified but it seemed to be always on.
Old Feb 22, 2016 | 09:42 AM
lVloses's Avatar
I use the remote wire on that goes to the factory amp. I just tapped in to that and ran it to my subs' amp.
Old Feb 22, 2016 | 02:23 PM
blkchevyz's Avatar
did you do that at the amp?
Old Feb 22, 2016 | 04:29 PM
lVloses's Avatar
Yes. Tapped it at the stock amp pretty much then ran my 2 feet of wire or whatever it was to my subs' amp.
Old Mar 30, 2016 | 09:43 AM
kinglt-1's Avatar
That is not the correct way to do it...You really need to run a dedicated power wire from the battery to the amplifier. Active or Powered is essentially the same thing other then the amp is built into the box with powered.
Old Mar 31, 2016 | 09:00 AM
blkchevyz's Avatar
i think he was referring to the single wire to tell the amp to turn on or off.
anyway i couldnt figure out what wire to use and when i tried to use the sun roof wire someone used on here it the amp stayed on. so i just used the feature that turns the amp on when it gets a signal from the speakers.
Old Mar 31, 2016 | 09:01 AM
blkchevyz's Avatar
oh and that sub/amp kicks *** for the price.
