SS remote srart.. grumbles..
I must have asked 5 times if it was a new revision, and not just a new part. They assured me it was a new revision.
Got in the car and of course the tire pressure monitors don't work either.
So I set up another appointment. Come in...I meet family there and go get something to eat. On our way back we pass my vehicle on the road. I didn't see a reason they would need to be driving the car around when they're trying to fix the remotes. Their excuse was that they had to drive it for the Tire Pressure Monitor to relearn.
Can someone verify this for me? I don't know.
However, the problem is still not fixed.
Finally they agree to give me a loaner the following weekend and keep the car for a week to get it resolved. I get the loaner the next weekend. 2 hours later they call me and tell me its fixed. However, I couldn't get to the phone or come in that day as I went out of town after I dropped it off. Good thing though, because I talked get a call the next day saying that it wasn't fixed after all and needed to keep it.
Finally I get it back at the end of the week and everything seemed to be working ok. Except that they didn't install the pillar trims correctly and after closer inspection, noticed that the had broke both of them.
It's been about 3/4 weeks now and it definitely has better range than before. I'm not sold that the range is what it should be...but it's good enough. I found out that they installed a completely different antenna and receiver. The antenna in the windshield is now disconnected and the new one rests in the driver side pillar, which may be why the distance still doesn't seem completely 100% (more like 90%).
That being said...I still have a problem where the panic alarm goes off randomly when I open the trunk. I don't know why, but it scares the crap out of me and I know it's not me accidentally pressing the button because I account for that when I open it and it still goes off randomly. Weird.
The only other thing is that I did notice once or twice within the last week the turn signal started to make the same strange sound it would make when I was having the problems before. So if history teaches me anything...I'm in for some more headaches....suck.
I am assuming that you have a ‘06 or a ‘07 Monte and where you asked about them taking your car out for a drive to relearn the tire positions. That my friend is a bunch of B.S. for it to relearn the tire position you have to get it to the relearn screen on the DIC and push the check mark button to start the process. Then you let about 5 seconds of air out of the left front then the horn honks then the right front honk, then the right rear honk, then the left rear honk turn the key off, fill the tires back up with the proper amount of air, done! The book says nothing about driving it to relearn. Sounds like they’re giving you the old dick with him long enough and he’ll just give up treatment. My old antenna is also cut off and just stuck in the hole on the a-pillar and it works good, atleast 200 feet.
