GTP grand prix question
Tate
www.zzperformance.com
www.3800performance.com
Those are my favorite vendors, have him spend countless hours on www.clubgp.com there is a ton of good info on there including mods for "newbies". You really want to make sure that you don't put too small of a supercharger pulley on that car unless you have the supporting mods. Detonation will destroy the 3800 pistons over times. If he stuck with a 3.5" pulley, he would probably be alright without any tunning and just intake and exhaust.
Find out what your buddies goals are. If he really want to get into the mods, I would recommend an interchangable pulley system (a hub mounts to the supercharger shaft and you can bolt different sized pullies to the hub depending on the how much boost you want to run) so he can drop pulley sizes easily as he continues to mod. I used to run different sized pullies in the summer and winter and it's nice being able to swap pullies in 5 minutes.
Just make sure you don't run too much boost without the supporting mods (cam, headers, Alky injection, intercooler, etc.). Avoid the one wheel burnouts (the GP has a weak differential), and if he wants to run in the 12's, make sure he has some money in savings because things will probably start to break. The 3800 can be put into the mid to high 13's (just bolt-ons) and still stay very reliable. Just have your buddy spend some time on ClubGP so he doesn't begin modding blindly, he'll waste alot of money in the long run, most do.....I'm guilty also
Some of SLP's stuff is expensive, and the welds are a little frankenstienish on a couple of their mufflers I had. Had to paint them so no one would see the crappy workmanship.
1. Good intake (CAI or FWI)--$60-$250
2. 3.5 pulley--$65-$125
3. 3" DP--$250
4. PCM--$99
If he is serious about the 300 WHP then he will be looking a a little bit more again see my sig below.
HTH,
Tate
