Predator - Modify Tune - Fan settings...
anyway... what are the Diablo Tune No DOD settings set to? What are the stock fans set at??
What is ECT?? Can or should I change the fan settings to help keep the engine cooler? If so, what should I set them at???
Thanks!!
-Lew
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
thanks guys!
"You can raise the fan speeds if you want it will help cool the engine,
only thing is that they get kind of loud and some people do not like that."
"If you go into modify the factory hp tune, you can see where all of the
factory fan settings are in the fan parameter. You will likely be hard
pressed to improve the cooling unless you add a cooler t-stat to go along
with it, like a 180°."
Tate
