VP 112 race octane
Old Sep 6, 2007 | 09:26 AM
scarlett's Avatar
Default VP 112 race octane
Any one know if it's safe to throw a 20 liter jug of VP 112 octane to hit the track one evening?
Cheers,
Old Sep 6, 2007 | 09:55 AM
06 SS's Avatar
why would you need to add it? Do you have knock at WOT?
Old Sep 6, 2007 | 10:25 AM
djfeezy's Avatar
Not really worth it unless your tuned for it.
Old Sep 6, 2007 | 10:31 AM
scarlett's Avatar
It would not give you no extra power? If I run say Shell 91-92 octane I see a little KR. If I run 94 ethanol Husky I get no knock.
Old Sep 6, 2007 | 10:46 AM
djfeezy's Avatar
If your getting no KR using the 94 octane, then use that. There is no need to go with 112 octane. You typically want to use the lowest octane that you can that will not give you KR. Once you start showing KR, the car will start to pull timing. So yes, you will get alittle better performace with the 94 showing no KR. But like I said, not worth it to pay for 112 when 94 is doing the job.
Old Sep 6, 2007 | 11:50 AM
live2ride's Avatar
I thought the 112 had lead. I know you said at the track, but if you liked the results I'd bet you would dump some in on a regular basis and then your cat would suffer.
I agree with the others, no KR, no need, unless you want to try and bump up the timing and by doing so create a situation where KR rears its ugly head.
Old Sep 6, 2007 | 09:30 PM
BariPlayer's Avatar
VP 112 has a fair amount of lead in it; about 4g/gallon if memory serves. If you aren't running a lot of static compression or a forced induction induction application you'll actually run slower since the car will be pig rich. You'll also take out the cat real quick, too.
By way of contrast, at the track I run VP C16 (116 motor octane) in my '87 GN which has a good sized turbo running a fair amount of boost.
Hope this helps,
Morgan
Old Sep 6, 2007 | 11:05 PM
Nacho SS's Avatar
If you tune for it....then its fine. But if you run it stock it will bog because the engine will pump the same amount of fuel, but with more octane.
Old Sep 6, 2007 | 11:27 PM
BariPlayer's Avatar
Nacho,
I mean no disrespect, but how much experience do you have working with high octane leaded fuels? 112 octane is far too much for a stock compression N/A application; the only reason to step up to such an octane are for the reasons I noted in my post above, or if one was running a siginificant amount of spray on a high compression motor. If I were to put a 100 shot on an LS4 car I'd be inclined to run VP Red (100 octane unleaded) or even VP Motorsport 103 (also unleaded) to give me a little extra insurance at the track. Prior to getting her Charger my spouse used to run a LSX guru/dyno-tuned '04 LS1 GTO out at CA Speedway and pull low 13s at 104 on 91 octane. Even if scarlett were to employ additional tweaking the 112 would hinder, not help.
Regards,
Morgan
Old Sep 6, 2007 | 11:35 PM
Nacho SS's Avatar
Originally Posted by BariPlayer
Nacho,
Regards,
Morgan
No disrespect taken...I was thinking theoretically, you could tune for pretty much anything in HPT. I'm not going to be the one-up guy and have a peeing match over gas in a car forum, so I'll divert to whatever you say. You obviously have some hotter cars than I.
Have a nice night,
Nacho.
Old Sep 7, 2007 | 12:57 PM
Area47's Avatar
you do not have enough compression to warrant the need for 112 octane. i doubt you are spraying over a 100 shot to it, or 10 psi of boost.
