At the track pics and videos...
, but no problems after a restart or when I drove home. Thanks guys. Help me make a low 13 sec. car ALL DAY!!!
http://i197.photobucket.com/albums/a...GXPStaging.jpg
http://i197.photobucket.com/albums/a...PvsTransAm.jpg
http://s197.photobucket.com/albums/a...XPvsStang1.flv
http://s197.photobucket.com/albums/a...XPvsStang2.flv
http://i197.photobucket.com/albums/a...ImpFusion1.jpg
http://i197.photobucket.com/albums/a...ImpFusion2.jpg
http://i197.photobucket.com/albums/a...nicslights.jpg
http://i197.photobucket.com/albums/a...h/Luminics.jpg
http://i197.photobucket.com/albums/a...PMSRWheels.jpg
Rest easy now, Lil Bro. Cancer has no power over you now. Please check out YOUTUBE and search Carter Finger and watch for Rhonda and Mariah.
http://i197.photobucket.com/albums/a...lBroCarter.jpg
http://i197.photobucket.com/albums/a.../GXPPedals.jpg
http://i197.photobucket.com/albums/a...PMagnaflow.jpg
http://i197.photobucket.com/albums/a...zpgh/GXPKN.jpg
http://i197.photobucket.com/albums/a.../GXPEibach.jpg
Notice the tips are not under the bumper cover anymore, they are moved to the edge.
http://i197.photobucket.com/albums/a...kelighton1.jpg
1. If your gonna keep modding then I say invest in the HPTuners instead of just a tune from someone. That way you can always adjust for other mods or weather changes.
2. Love the shift kits, but don't go to aggressive with it, or on that little pesky 1-2 shift if you get any traction then you can kiss your Input shaft good bye.
3. You can run 1.8 rockers and a few places sell them (I'm sure some one will pop in and tell you where) and I believe that Intense-Racing.com sells a Spring/Rocker/and push rod package. It's not on there website but they carry them if you send them a message or call them then you can get them.
4. Be careful when getting different springs then what is called for. Just because GTP springs will fit doesn't mean that they have the same load rating that you need. I was under the impression that Eibach sold GXP springs for the 05 GP GXPs which would be the same as any other GP GXPs if yo ucan find them.
5. I wouldn't change the gear ratio to 3.29s if I were you, the reason I say this is because that's the gearing in my 04 Comp G and I push right at 325 to the ground and 1st gear is worthless at anything over 1/2 throttle unless I'm on the DR's and even the 1st part of 2nd gear sucks. When your dealing with only 4 gears and 1 of them is useless then it makes for not so much fun.
Tate
comp hardned 7.4 pushrods
comp 918 springs.
good to go. hell i know baddls1 posted all the parts numbers and some other stuff on here somewhere of what he used on this top end kit he pieced together.
all of those parts can be purchased through summit or jegs.
rocker pic
