stall converter
Tate
A torque converter (TC) is used to get the power from the engine through the transmission to the drive line. It is between the engine and transmission. It operates in place of a clutch on a manual transmission. As the engine speed goes up, fluid is spun around inside causing the internal parts of the TC to eventually spin at about the same rate transferring the engine speed to the input of the transmission.
Stall speed is the point where the engine RPM is about the same as the input RPM of the transmission. Generally smaller diameter TC’s allow the engine to rev up higher (more torque) to get the car moving faster. If traction is lacking and is not improved increasing the stall will make things worse.
Just my take on this, the stocker is good where it is....
Now, a tighter converter would be good, but I'm not sure that you're going to find a more efficient TC than what you get from the general. They've been experimenting with more efficient stators for a few years now. I got one in a 3900 stall 9" in my 96 Impala and it's very efficient. You'd hardly know it was a 3900 stall TC and it runs very high MPH to the ET in the 1/4.
The stock stall is most likely around 1800 or so and is certainly not loose. Likewise, I'd bet that DOD is rarely ever active when the TCC is unlocked. So the stall of the TC really isn't relevant to DOD.
****edit
A high stall TC is a great mod for real SOTP performance gains, in a RWD vehicle. It'll pin you back in the seat and get 4000+ pounds out of the hole in hurry, IF YOU HAVE TRACTION!!!. However, it's counter intuitive in a FWD street car where getting traction for a hard launch is a HUGE challenge. my $.02
****edit
****edit
hehe no I have not, and we as in cars with the LS4. Actually a '96 Monte Carlo 3100 has a 1800 RPM stall for the sake of trivia. DOD transition is noticable sometimes when cold. A time when the TCC is not engauged... It would defintealy be felt with a tighter converter
This thing drives tighter than my Yank TP4400
It's a bit tighter than my TCT 4000 nitrous converter
And the kicker, it drives EXACTLY like my Vigilante 3200 stall equipped stock long block '98 Z28 did. I mean to a "T". It's pretty badass, haha.
You guys would know better than me any factory ratings since I haven't read too much about 'em. But for real world, that's what it feels like
