How do you remove the oil filter?
Old Mar 8, 2008 | 11:10 AM
Martin88XJ's Avatar
Default How do you remove the oil filter?
I just changed the oil in my 08 LaCrosse Super when I hit 2000 miles and had 69 percent on the oil life meter. I have use of a garage with a lift to change the oil.
I filled it with Mobil 1 5W-30 and put the corvette mobil 1 factory fill cap so people know it filled with Synthetic.
I went to remove the filter and GM put it on extra tight. I backed off the filter and had oil leak out from above.
I am wondering if anyone had punched a hole in the filter and let oil drain out before turning off the filter?
Just wondered what people did to minimize oil running on your hands.
Old Mar 8, 2008 | 11:19 AM
Count of Monte Carlo's Avatar
I guess you could do that But i just have extra paper towels ready...Plus I wear latex gloves when I change the oil..
Old Mar 8, 2008 | 11:23 AM
TiredGXP's Avatar
Old Mar 8, 2008 | 11:41 AM
BuffaloSS's Avatar
I've tried the ziploc trick with little success, but you could try that. Put a ziploc over the filter and then twist the filter all the way off. The baggie will catch MOST of the oil and the filter when it drops.
Also, I've never had trouble getting the filter off, though. The dealer did my first OC and I;ve done the rest with Mobil1 oil and filter.
Old Mar 8, 2008 | 02:49 PM
Sint3k's Avatar
I just have a really big oil pan. When it comes to oil expect your hands to get dirty.
I just noticed that OnStar Shows when you reset your oil life monitor AND shows your mileage over the year and shows your daily mileage... neat!!! as for getting your oil filter off i never tighten it more then hand tight and i can always remove it somewhat easily. I also put old oil around the seal helps the seal from sticking and makes a better seal and then clean everythign with brake or carb cleaner so i can make sure i don't have any leaks that i wont question.
Old Mar 8, 2008 | 04:36 PM
Mels SS's Avatar
I use K&N oil filter and it has a built in nut you put a wrench on so you can get it off easy.
But I just go hand tight on the filter
Old Mar 8, 2008 | 05:15 PM
CTBSS's Avatar
Is it just me or was it really dumb to put the drain plug in the FRONT of the pan? If you use ramps or a jack to change oil, you are leaving quite a bit of used oil in the back of the pan!!
Old Mar 8, 2008 | 05:25 PM
TiredGXP's Avatar
Ha!
I couldn't figure that one out either.
Old Mar 8, 2008 | 05:49 PM
Sint3k's Avatar
If you looked at oil results you will know it doesn't matter if you mix a few ounces with all new. The main reason for changing oil is viscosity and water contamination. Oil filter basically gets rid of everything else
Old Mar 8, 2008 | 06:19 PM
CTBSS's Avatar
I let the car down level when changing my oil and there is close to a quart still left in the pan. The dirty oil along with the contaminants that are left at the rear of the pan are just plain scary!!! It's just plain STUPID to put a drain plug where it is going to be a high point for most "do it yourselfers"!!!!!!
Old Mar 8, 2008 | 06:23 PM
Well I dont think I could do this because I am NOT the svelt prince of towne..., but you could try putting the rear wheels on the ramps and go at it with the nose down. maybe drive up on some 2x4s and then back up the ramps. makes for extra work but its dooable....
I put in 6 quarts to fill. Including whatever I put into the filter. I like to run the Purolator Pure One filter. Got a socket for that. Or a Mobile 1 filter, use the band for that.
Old Mar 8, 2008 | 06:28 PM
CTBSS's Avatar
Or i could just walk around to the back of the car, pick it up and shake it a little!!
Old Mar 8, 2008 | 06:32 PM
the thought of that LOLOL
Old Mar 9, 2008 | 10:30 AM
Martin88XJ's Avatar
I appreicate the comments! When I change oil the next time I'll try the hole punch method. I did go though several paper towells to get the filter off, glad to know I am in good company
Old Mar 9, 2008 | 11:07 AM
JNS_SS's Avatar
remember this is a 5.3 same as the truck they use the same oil pan as on the truck but on the truck the engine is not sideways this engine was not designed for side mount gm has to cut some corners
Old Mar 9, 2008 | 10:52 PM
Kazmaniac's Avatar
I've had several factory installed filters that were crushed by my band clamp taking them off, including an Impala I had GM roadside assistance pick-up because I ripped the thing in half trying to get it off. Rage: when a 20 min. oil change turns into a deadlined vehicle.
My personal opinion is over-torqued w/o oiling the filter seal first.
I use NAPA Gold filters hand tightened, no problem removing.
Old Mar 10, 2008 | 07:44 AM
Mels SS's Avatar
Remember this filter easy off!! Also I drive up ramps and use my floor jack to lift the rear
all the oil removed!!
Old Mar 10, 2008 | 09:58 AM
BuffaloSS's Avatar
Good thinking, Mel. It would be so much easier to do it that way. Where do you jack up the center-rear, though?
I park the car on the street with the passenger wheels on the curb. The crown of the street & drain give me enough room to reach under, pull the plug, R&R the filter, and then put it all back together. PITA? Yeah...but the car stays flat and I get MOST of the oil out.
Old Mar 11, 2008 | 08:55 AM
Mels SS's Avatar
I jack the car on each side and use stands. I have a speed jack two pumps and the car is in the air.
Old Mar 11, 2008 | 08:59 AM
BuffaloSS's Avatar
Is there a center point back there that can get it up all at once?
