Question Regarding Cold Air Induction for an 05 GXP
What you would need to do when your installing (this info is also for everyone else as well who either has or plans on installing K&N intakes):
Once you're running the trim along the front of the shield of your Intake(pointed towards the front of your car) there has been an issue with the rubbery foam splitting away from the bottom part of the trim(that clings to the sheild). I've seen this on a lot of LS4 engine bays including mine!! This issue is caused by the severe curve/drop along the sheild.
Once this has happen, you can easily order FREE trim from K&N!! But to deaden the issue, either cut the trim a inch short so that it doesn't stretch the foam severely to the point that it rips away Or the ghetto way, add a small strip of electric tape across the foam at the very end/bottom. Or even try to keep it loose on that roller coaster drop while applying the trim. These are proactive ideas that you can achieve, before that day you pop the hood & show off your engine bay & notice the hangy foam dangling off the shield. Sorry for babbling but to answer the rest of your question: you can order hogan down pipe, flip your motor mount or purchase the poly motor mount, strut bars, Diablo U7191, HS 1.8 rockers, shift kit, ls6 yellow springs, even spray it!! as the years progress, we should get more mods for these LS4s hopefully!
I want headers, I want Headers, I want Headers!!
Stealth, you have an '05 and you say they both work so I will trust what you say. I think for now I will go with the CAI box like you have (looks really good under your hood and it says 05 application). Unfortunately there is no dyno test that I've found to show any difference in HP and TQ comparing the K&N to the CAI but I'm sure they're both pretty close and are priced pretty much the same. CAI is on back order for 1-2 weeks so I hope it's worth the wait.
Thanks again everyone for your help! Great info and list of mods Carlocrusader, thanks!
Who does those ported TBs?!
& Your TRUE CAI=Kewl!! & I mean that in both ways!!
https://ls1tech.com/forums/showthrea...porting+intake
The special is over but i'm sure they still do it.
