My ambitious project
Old Oct 13, 2008 | 12:10 PM
  #101
neilownz's Avatar
mixerda: so you have a 07?
Old Oct 13, 2008 | 12:21 PM
  #102
mixerda's Avatar
couldn't I just replace the whole timing set and call it good?
and yes 07 imp SS
Old Oct 13, 2008 | 12:28 PM
  #103
neilownz's Avatar
is there a sensor on the timing cover?
http://www.lingenfelter.com/Merchant...Category_Code=
you gotta pull off the oil pump and stuff to see if theres holes for it.
im assuming someone might have put a 3 bolt in a 6.0 ls2 gto. might wanna look at that section of the forum.
Old Oct 13, 2008 | 01:51 PM
  #104
BADDLS1SS's Avatar
and yes 07 imp SS
The reluctor signal is different on the 07's (which is obvious based on the reluctor bumps on the face) So if you change the whole set to run a 3 bolt style, it doesnt matter the thing wont work right because the signal will be wrong for cam position to the computer.
Either you gotta run an 07 LS2 cam like the one laying around i have or or get a custom one from COMP for the single bolt.
Old Oct 13, 2008 | 01:54 PM
  #105
BADDLS1SS's Avatar
Ah ha!! thats what he needs!!
In theory all you should need from this kit are the bolts and the gear! His lucky day!
Old Oct 13, 2008 | 03:10 PM
  #106
mixerda's Avatar
awesome find it's on order I'm going to need to replace the chain and crank gear anyhow though. I found about 5 teeth on the cam gear that look a bit bent :< could of been from when I had to crank on the bolt to remove the gear but kinda off in different area of the gear so I dunno, I'd rather be safe than sorry and have to rip it back apart lol. Thanks for the info really helpful you guys rock.
Old Oct 13, 2008 | 08:33 PM
  #107
Brian396's Avatar
Crap if you allready ordered, but anyway http://www.superchevyperformance.com...p/12586481.htm
Old Oct 15, 2008 | 11:55 AM
  #108
BADDLS1SS's Avatar
If anyone is intrested : https://ls1tech.com/forums/lsx-parts-sale/1002486-12565308-02-04-ls6-cam-fs.html
It was actually an 02' + cam i had in there, i never ID'd the cam till this morning, i just knew the history of the prior car it was in.
Old Oct 15, 2008 | 12:06 PM
  #109
Formula350's Avatar
Originally Posted by BADDLS1SS
If anyone is intrested : https://ls1tech.com/forums/showthread.php?t=1002486
So any new cam plans currently, or stock for now?
Old Oct 15, 2008 | 01:04 PM
  #110
BADDLS1SS's Avatar
Gonna get it to the track with 100% stock valvetrain aside from the springs. To be honest it "feels" better this way... idk... i wasnt convinced the rockers did **** either. So it willl be cooler to me anyway if i can get the thing damn near 12s with nothing but traction, a tune and and catless DP.
Again its my DD with pep, not my race car.
Old Oct 16, 2008 | 11:01 AM
  #111
SILVER LS4's Avatar
Well im certain the intake is the "resctrictor" in this case. No mattter how much u port that intake its still a turd. I think im gonna cash in my chips and get a new colorado with a 5.3 in it real soon, there are 2 of those so far in SE wisconsin.
Keep everone/me posted on the Colorado stuff. A v8 in that thing is quite interesting, to me anyway. Can't get a reg cab, have to get an extended cap or crew cab. Would be a fun truck with tons of potential.
Old Oct 16, 2008 | 01:05 PM
  #112
BADDLS1SS's Avatar
Will do.
I had an 04' Ext cab 4x4 with just the 3.5L and i had yank make a 3500 stall. 2.9STR converter for it with an intake and gibson exhaust. Was a fun little truck and really hauled *** for a 5 cyl, i bet mid 14s on motor with the above mods. Then i wacked it with a 100 shot on top of that with 4x4 burn outs across intersections lol
So i can just imagine how fun these little trucks can be with a V8.
http://www.converter.cc/customer_cars/
Old Oct 17, 2008 | 07:34 PM
  #113
neilownz's Avatar
http://www.speedinc.com/cont.cfm?cid=C0000752
theres just the cam gear and bolts.
Old Oct 17, 2008 | 09:53 PM
  #114
Formula350's Avatar
It's amazing that when the Colorados came out, I wondered how kick *** they'd be with a V8, then when I was browsing GM's database of engines I noticed it listed under the 5.3s lol I still can't imagine how awesome they'd be, but I bet every bit as good as a V8 S10, but better!
What all would be needed for someone to program a tune onto their LS4? If you're good at doing a 'mail order' (for lack of a better description), I bet my friend would be quite interested (He lives in Florida, so don't let my location throw you off)
Old Oct 17, 2008 | 11:48 PM
  #115
neilownz's Avatar
would be nice to find a regular cab short box full size. sucks that the 5.3 is only in the crew and extended colorados/canyons. i suppose someone will do it if it hasnt been done already...
btw i grabbed a bigger maf on ebay for $25 for when i put the bigger intake/tb/piping in eventually 15900023 is the part for that. pin are supposed to be the same as ours. some other guy mentioned it quite a long time ago https://ls1tech.com/forums/ls4-performance/668199-bigger-maf-iat-housing-finally.html
Old Oct 18, 2008 | 12:40 AM
  #116
Formula350's Avatar
Full size Colorado? o_0 Wouldn't that be a Silverado
Old Oct 18, 2008 | 01:23 AM
  #117
neilownz's Avatar
yep that would be correct... a 1500 or 2500 chevy/gmc with a 5.3 or a 6.0 would be nice to mod.
heres a colorado "ss"
http://cgi.ebay.com/ebaymotors/Chevr...mZ120319502392
Old Oct 20, 2008 | 02:23 AM
  #118
mixerda's Avatar
well ladies here is the start up after the cam install, **** quality on vid on my part :< was my fault could only mount the camera up against the wall so I'll make a better qual vid later.
http://www.youtube.com/watch?v=5kbHtl_HmDE
Old Oct 20, 2008 | 11:35 AM
  #119
neilownz's Avatar
sounds good. tune it yet?
Old Oct 20, 2008 | 04:14 PM
  #120
mixerda's Avatar
nope gonna have the exhaust cutout installed tomorrow then try to have the tune done tomorrow as well, if not tomorrow some time this week it will get done
