FS wet and dry nitrous kits NX heater crane high6 ignition holley regulator cheap
first i have a wet compucar kit...the lines and noids are compucar and will support up to a 225 shot they have a lifetime warranty and have only had 1 bottle ran through them....i didnt like the compucar bottle and brackets so i purchased the anodised blue NOS bottle with matching blowdown tube...also the black graphite NOS brackets...bolted down its a nice clean setup...
the nozzle is a NX shark nozzle the compucar was too hard to get jets for and the shark nozzle has a really good rep,although i dont have any jets...the nozzle will except standard nos or NX flare jets though...
this kit works flawless and is a damn steal at 250 shipped to the lower 48..the bottle blowdown tube and brackets would cost you that much...
250 shipped
![](http://i177.photobucket.com/albums/w216/5_02ls1/parts1.jpg)
![](http://i177.photobucket.com/albums/w216/5_02ls1/parts2.jpg)
![](http://i177.photobucket.com/albums/w216/5_02ls1/parts3.jpg)
next i have a crane Fireball high6 ignition...it is all in original packaging and works flawless it has a ford tfi coil and harness included...there is instructions to wire this to damn near anything...would be great to use on a distributor setup
150 shipped
![](http://i177.photobucket.com/albums/w216/5_02ls1/parts6.jpg)
![](http://i177.photobucket.com/albums/w216/5_02ls1/parts5.jpg)
next i have a new Holley fuel pressure regulator...its low pressure would work awesome for a standalone setup...its the black regulator...
25 shipped obo
![](http://i177.photobucket.com/albums/w216/5_02ls1/parts4.jpg)
last i have an NOS dry kit everything minus a bottle
first ill tell what you get
nos super powershot noid will support 175bhp shot
bracket
all fittings
all lines total around 17-18ft
n20 filter
wot tps box
fpss
rpm activated switch
nozzle with collar and upgraded -4an nozzle line
this is a nice kit when installed it has its own harness with relay and inline fuse all you have to actualy wire in is the tps activation box it wires inbetween your tps plug in...then you just need battery power switched power"master" and a ground...i will try to label everything...but its really simple to install....i was running this setup without a jet it flows right around 150twhp this way....i think i have a couple small jets ill give to the buyer...
also the brackets with the kit were damaged when i cut them out of my car...if you are welding them in they will work normally i wouldve just thrown them away but i thought id add them with the kit...
this is also a giveaway with a bottle this kit was over 700 new...
150 shipped
![](http://i177.photobucket.com/albums/w216/5_02ls1/parts7.jpg)
haha i almost forgot i have a used NX bottle heater in great shape
50 bucks ship[pped
250 shipped
150 shipped
25 shipped obo
bracket
all fittings
n20 filter
wot tps box
fpss
150 shipped
50 bucks ship[pped
![](http://i177.photobucket.com/albums/w216/5_02ls1/parts8.jpg)
