9.46@141 advanced induction 383
http://www.youtube.com/watch?v=a60M2SkIUnc
found a few bugs this weekend and finally got the car to make a good run
That is getting it done! What was the run break down? I saw the 6.01 8th in the video.
Those times are impressive considering the lack of exotic parts in your setup.
http://www.advancedinduction.com/Harvey.html
Congrats on the new best. Planning to hit it with a little more?
1995 Z28
3470-3500lb Raceweight
383cid LT1 Eagle/SRP Shortblock
11.5:1 Static Compression Ratio
Ai 215cc TFS LT1 Cylinder Heads
Ai LTx Pro-Ram Single Plane
Accel 4bbl Throttle Body
Ai Custom Roller Cam & Valvetrain
Jesel 1.6/1.6 Ratio Shaft Rockers
NX Wet N2O kit - #52 Jets
Hooker 1-3/4" Long Tube Headers
Meziere Electric LT1 H2O pump
TH350 Automatic Trans
3600rpm Converter (Mike see's 4k currently)
Moser 12-Bolt - 4.33 Ratio
FAST XFi ECU - Self Tuned
QA1 Front Shocks
Spohn Torque Arm
Spohn Drag Bar
I am runnin m/t 28-10.5 stiffs. I just put the 4.33 gears back in last weekend, but I also shift the car at 7200. It is 250 off the line, but the cam is on a very tight lsa so I don't know how much that effects the hp of the nitrous.
https://ls1tech.com/forums/lt1-lt4-modifications/994549-ai-383r-long-block-tfs-215-heads-goes-9-6-139-9mph-na.html
That is NA on pump gas. And I'm not comparing the cars, only showing you another that runs ported TFS heads into the 9s.
