passenger sag
Old Oct 31, 2008 | 11:50 AM
LT_WON's Avatar
Default passenger sag
Just installed Eibach sportline kit and rear control arms for my 1995 LT1. Total noob question but now the rear passenger side is sagging about 1"1/2 lower than the drivers. what can i do to fix this problem? adjustable panhard? brackets? When in doubt ask the pros.
Old Oct 31, 2008 | 12:05 PM
Ls1Bait's Avatar
Almost sounds like it could be in the spring but Ive never done a set on mine so im not sure. A adjustable panhard bar only centers the rear end so I dont think that would solve your problem. Im sure some of the lowered guys will chime in.
Old Oct 31, 2008 | 12:12 PM
the_merv's Avatar
Did you forget to put the Isolater back in?
Old Oct 31, 2008 | 01:34 PM
z28rob18's Avatar
u could get an air bag and put it in the spring my airbag lifts the passenger rear wen i fill it up to help the torque on launches
Old Oct 31, 2008 | 02:05 PM
LT_WON's Avatar
isolater is back in no left overs haha, . the air bag is a good idea if nothing else comes up. anyone know where to get those. thought i saw some at one point in summit or jegs but not sure i thought i had heard about this similar problem a while back but no resolution...
Old Oct 31, 2008 | 02:17 PM
the_merv's Avatar
Switch the Springs around and see if you have the same problem on the other side..
Old Oct 31, 2008 | 02:23 PM
koolaid_kid's Avatar
You should not have to put the bag in. That would be a bad thing, compensating for an issue from something else. You should have the same results before and after. The panhard bar only centers left to right, the control arms front to rear.
You need to go backwards, and find out which change makes the difference.
BOL.
Old Oct 31, 2008 | 03:38 PM
LT_WON's Avatar
good idea on moving the springs around ill try that see if it affects the driverside. love the low stance on the sportlines wish they didnt have a bad track record with f bodys.
Old Nov 2, 2008 | 07:11 AM
petechapter50's Avatar
stop picking up fat chicks hahahahahaa
