Will the ZZ4 cam work in an LT1?
Hydraulic Roller
Duration @ .050" Lift
208 221 .474" .510" 112
TIA
Darren
Scott
Dave
Dave
So far its majority saying it should work/can be made to work, but noone is confident it seems.
Thanks for the replies so far guys.
It does work, cuz I run it. I had to have the front drilled for 50 bucks to open up the hole and since no one actually sells the correct sized dowel pin I took a carbide tungsten drill bit and cut and had it tapped in. You have to run a later model style Optispark of course and it runs great. I've got over 5000 miles on it now and it has quite a bit more bite than stock.
I have to agree with Bizzzatch though, its more work than I would be willing to through for that little camshaft. Just my .02
I wanted some extra performance without hurting gas mileage too much. Then add the rest through N20.
Wish I could say it would crank out 400hp though for sure. But I think with the 1.7rr and it's new lift numbers it can come close if not match it. Nick you might have a better idea, what do you think??
w/ 1.7rr lift goes to:
.537
.578
All with a 208/221 duration on 112.
I'd say that's a max effort fuel conscious cam packing a comparable "bigcam" torque+HP curve IMO.
I do like the GM 847 cam though. When I picked the zz4 it was that or the ever common LT4 Hotcam or the CC306 but I didn't like what they did to gas, the 847 tho I'm sure hurts gas also, but it's return looks inargueable so far from what ppl have been getting out of it, 440 HP would have convinced me to go big also but I didn't know of the 847 at the time.
