View Poll Results: what would you rather have wet or dry nos
wet
26
96.30%
dry
1
3.70%
Voters: 27. You may not vote on this poll
what would u rather have wet or dry
WELL ... I have had both. My dry kit was simple and very awesome. My wet kit hit a ton harder. I enjoyed both kits. If i did it again, It would be a Wet shot. Here are the two kits i have used.
Dry-- http://store.summitracing.com/partde...5&autoview=sku
Wet-- http://store.summitracing.com/partde...5&autoview=sku
wet. it's safer cause you don't have to worry about the MAF adding the extra fuel. also, you don't have to worry about the stock injectors maxing out, because there is no extra load placed on them.
plus....you can run a bigger shot.
Guest
Posts: n/a
LT1 Dry kits do not use the MAF for fueling...they bleed a portion of the nitrous flow to the fuel pressure regulator....this will drastically increase the fuel pressure therefore forcing more fuel through the injectors with each pulse.
