242/250 112, stockish heads dyno
Old 02-07-2009, 05:04 PM
zigroid's Avatar
Default 242/250 112, stockish heads dyno
I put my car on the mustang dyno at PSI motorsports to see what she puts down as a baseline. I ended up making 365 rwhp @ 6400 rpm and 355 rwtq @ 4500 rpm. I have a stock airbox still so I pulled that and dynoed it again. it put down 389 rwhp @ 6400 and 366 rwtq @ 4500 rpm. amazing the stock airbox is costing me 25 rwhp.
dyno vid: http://videos.streetfire.net/video/P...ird_634625.htm
(excuse the guy recording, he is one of a kind haha)
crappy cell phone pic of dyno graph:
im just gonna quick copy and paste my mods list from my fquick site.
Performance:
Ed Curtis specced custom cam. 242/250 112 lsa, just under .600" lift
3 piece hardened pushrods
Comp cams pro magnum 1.6:1 roller rockers
7/16" rocker studs
PAC1518 valve springs
Trickflow guideplates
stock heads/valves, minor bowl work, good valve job
MrGasket .026" thick head gaskets
~11:1 compression ratio
BBK 58mm throttle body
meziere electric water pump
rebuilt stock bottom end with:
new main, rod and cam bearings
ARP rod bolts
hastings piston rings
Pacesetter long tube headers
Pacesetter Y-pipe with dual electric cutouts (not used on the dyno)
Hooker catback
Suspension/Chassis:
135,000 mile stock other than UMI tubular front K-member
Drivetrain:
Locally built 4L60E transmission
Yank Pro Thruster 4000 rpm stall torque converter
4.11s will go in to replace the stock 2.73s once its running
Electronics:
PCM tune by Ion @ madz28
overall I am VERY VERY pleased with how it runs. I was asked what I thought it was going to make before I dynoed it I said 300-310 rwhp. you can imagine the shock I was in when I was told i just laid down 365 rwhp.
and finally some pics of the fun:
oh and I would like to say thank you to everyone who told me it was a mismatched combination, it would never idle, it would peak power too high, it wouldn't operate power brakes, it would be impossible to tune. you made my day even more enjoyable knowing I proved so many wrong. most of these people don't post regularly on this site, but they read it. thanks guys
Old 02-07-2009, 05:12 PM
FlamingChicken's Avatar
what about the ones that told you the stock airbox was costing you alot of power? jk, nice numbers. post up some times when you get them.
Old 02-07-2009, 05:15 PM
zigroid's Avatar
oh I knew it was costing me power. how much, that is what I didn't know.
our local dragstrip opens up march 1st. I have 4.10s ordered and will hopefully have some kind of CAI in there. 11s all motor or blow it up trying. cant wait
Old 02-07-2009, 05:22 PM
SoxXpupPeT's Avatar
those are some good numbers. but how could you do all those mods with a Stock intake box?!?!?! wouldnt a CAI be first on everyones list but now you need an LS Lid!!!
Old 02-07-2009, 05:24 PM
zigroid's Avatar
I sold my SLP cai when I had plans on returning the car to stock. I used my stock airbox to just get the car on the road and driveable.
Old 02-07-2009, 05:28 PM
Elliott's94Z's Avatar
Damn them are some good numbers for running stock heads! And 25 extra ponies from the stock air box delete...damn.
Old 02-07-2009, 05:35 PM
Formula350's Avatar
Here's what confuses me... You are running pretty much stock heads, no porting done really and are pushing over .600 lift but you power band just keeps going up. I'd think that with stock heads you'd hit a plateau around 6100~ due to not being able to flow enough CFM. Our stockers only do like 215cfm for .500-.600+. Still though it's really great for cam and exhaust with a couple bolt ons I'm also surprised on the 25hp restriction that the stocker imposes! Is that power band so smooth due to how the Mustang Dynos work?
I think most of that +25 gain was from the !belt mod though
Attached Thumbnails 242/250 112, stockish heads dyno-belt.jpg
Old 02-07-2009, 05:38 PM
TABBED 5.3's Avatar
congrats on the numbers. so much for the "that cam is way too big" theory. incredible for a mustang dyno and a stalled auto. with the 4.11s, i dont see 11s being a problem. the 10 bolt on the other hand.....
car sounds great
Old 02-07-2009, 05:43 PM
you should easily hit 11s on motor if you can drive at all. nice stall with that much power = no problem.
BruceBufferTA's Avatar
Impressive! Can't believe that air box story either!
Old 02-07-2009, 06:01 PM
StealthFormula's Avatar
Damn man those numbers seem almost unbelievable! Car sounds pretty damn good we should meet up and do a little racing PSI has some ridiculous cars over there supercharged this, turboed that.
Old 02-07-2009, 10:25 PM
zigroid's Avatar
when I was there a car showed up on a trailer. it was a 69 Z28 with a 565 all aluminum BBC, EFI, 2 sets of injectors one 165 lb the other 95 lb, and a HUGE F3 procharger driven straight off the crank. the car that dynoed before me was a 93 LX fox body with a 434 SBC, brodix heads, huge dominator carb and a nasty solid roller cam that laid down 560 rwhp through a power glide. in the garage was a 05+ style mustang GT that had a 3v with forged internals, fully ported heads, and the east coast's only 3.4L whipple on a 3v 4.6 that had to use a custom sheet metal intake. owner said it was making mid 600s on pump gas before and with a few changes he is expecting to make close to 800 rwhp. there was an LT1 trans am with a t76 turbo and a nice FMIC, a mach 1 with a kennebell, all kinds of nice toys. my car was probably the slowest one there lol.
Old 02-07-2009, 11:12 PM
fergymoto's Avatar
How do you like that stall for driving on the street? Is it good or is it on the loose side? I have been considering a PT4000 Yank for my car. Shoot me a PM if you don't mind. Congrats on the numbers
Old 02-07-2009, 11:17 PM
zigroid's Avatar
I think the stall will be better with gears. if I just give it normal throttle it will stay around 2500 rpm. if I have to give it more gas or go up a long hill it will go up to 3000 rpm or so. it is loose but I dont mind. it becomes apparent when you give it more gas and the rear end is skating all over why I have such a big stall
Old 02-07-2009, 11:35 PM
fergymoto's Avatar
Sounds pretty good to me, especially for being on 2.73 gears. My 3400 Fuddle I currently have behaves pretty much identical to what you just described. That's with 3.42 gears too. When are you changing your gears? I would like to hear about it after you do the gears.
Old 02-08-2009, 01:05 AM
suzookiegsxr's Avatar
Awesome numbers man, I think these lt1 heads flow a lot more than people give them credit for, I swear my 224/230 lt1 is faster than my ls6 N/A
Nice to see the LT still representin'
Old 02-08-2009, 02:15 AM
LM97Z's Avatar
Those are some very good #s, I myself am not surprized at the loss of HP from the stock airbox, you won't see those gains on a stock engine going to an aftermarket box, but from what you've done, the stock box was way too restrictive & wasn't cutting the mustard anymore, i'll bet from your VG valve job (most likely they had a back-cut too) & bowl work (thats were the main gains are), & that larger cam, you netted good #s, no surprize there neither, just goes to show what can be done. congrats on those great #s .
Old 02-08-2009, 02:19 AM
BOLO's Avatar
Awesome numbers. And I agree with your choice of cam size. Go big or go home. Alot of people here are just scared to run them. You just proved them wrong with their teeney weeney cam. Congrats Zigroid.
Old 02-08-2009, 10:26 AM
Yeah a set of 3.73 would really compliment that stall and the overall set up.
Old 02-08-2009, 10:47 AM
joelster's Avatar
Awesome numbers! That is the highest i've ever seen out of stockish heads. I'm sure 96capricemgr is pounding his fists in a temper tantrum right now saying it just can't be, lol.
Quick Reply: 242/250 112, stockish heads dyno
