What guide plates for my LE2 heads
Old 02-15-2009, 06:52 PM
airfix's Avatar
Question What guide plates for my LE2 heads
Hey guys, Ive done a search and have read so many mixed opinions im kinda confused now. What guide plates should I use on my LE2 heads with 7/16 nsa pro mag rockers. Ive heard some screw up the geometry?
Thanks In advance guys.
Ryan
Old 02-15-2009, 06:53 PM
RamAir95TA's Avatar
Go with the Trickflows.
Old 02-15-2009, 06:54 PM
airfix's Avatar
Perfect thanks bro.
Old 02-15-2009, 07:46 PM
Low N Slow's Avatar
Trickflows and GM didn't work out on mine, just get the Isky adjustables and you don't have to worry about it.
Old 02-15-2009, 07:49 PM
StealthFormula's Avatar
I run the Trickflows and they work great for me with my LE2's.
Old 02-15-2009, 07:54 PM
RamAir95TA's Avatar
Why didn't the TFs or GMs work for you?
IMO, the adjustable Isky's is just another opportunity to set something up wrong. The TFs and GMs are non-adjustable. Set and forget.
Old 02-15-2009, 08:28 PM
fergymoto's Avatar
In my experience with some non adjustable plates the rocker arm tip is not always centered on the valve and I have seen it as far as nearly half way off. You can take the chance and get non adjustable, or you can get the Isky adjustable plates.
I have used both, but the adjustable ones go on if/when the non adjustable don't line up.
Old 02-15-2009, 10:53 PM
Low N Slow's Avatar
They didn't center the rocker on the valve stem.
Old 02-15-2009, 11:02 PM
AChotrod's Avatar
I used trick flows but they did require a little modding for them to fit perfect.
Old 02-15-2009, 11:10 PM
za355tx's Avatar
Lloyd suggests trick flow guides for his setups.
Quick Reply: What guide plates for my LE2 heads
