Gaskets for Dart heads
Old 02-25-2009, 06:31 PM
kierstyn's Avatar
Default Gaskets for Dart heads
Hi guys just wanted to see what gaskets you are using with the Dart heads? Someone had told me they use a special intake gasket. Part numbers would be good intake gaskets,head gaskets can I get a thinner head gasket since they are 58cc to bump up the compression? Also do I need the square exhaust gaskets or will the D ports be fine? Thanks in advance. Also are these heads setup to use a stock length pushrod I already have chrome moly 7.2s going to check them when we install but would like to have most of my parts up front to do the install!
Old 02-25-2009, 06:40 PM
RamAir95TA's Avatar
Couple questions.
Are you using the Darts on a stock bottom end, or are you 355/383 etc.? What compression are you shooting for?
D-port header gaskets work fine. I highly recommend the Felpro 1406s. Nothing but great success with them.
You answered your own question about the pushrods. You should measure once you have them installed - chances are slim that stock-length pushrods will work.
Old 02-25-2009, 06:51 PM
kierstyn's Avatar
It is a 355 and looking to be around 11 to 12:1! With the pushrods just wondering what length people are using.
Old 02-25-2009, 06:52 PM
RamAir95TA's Avatar
Do you know your deck height? Is it stock?
Old 02-25-2009, 07:01 PM
kierstyn's Avatar
Im pretty sure it is I have the 7.2s in it know with the stock heads!
Old 02-25-2009, 07:07 PM
RamAir95TA's Avatar
Assuming you have a stock deck height (~.030"), using 3.48" crank, and -5cc pistons, you're looking at around 10.2:1 compression with a stock head gasket. Using an Impala gasket (.029") will net you around 10.7:1, which is about stock.
Old 02-25-2009, 07:10 PM
kierstyn's Avatar
Old 02-25-2009, 07:23 PM
kierstyn's Avatar
Sorry double post I have flat top pistons with 4 valve reliefs. yeah i am thinkin about the impala gaskets! I would like to set it up right.
Old 02-25-2009, 10:10 PM
James Montigny's Avatar
Exhaust ports on those heads are square.
I used a set of square gaskets and it worked perfectly.
Intake gaskets are standard LT1 gaskets.
Head gasket selection depends on the application, but you have the same options as any other LT1 head.
Old 02-25-2009, 10:11 PM
Here's a thread where we discussed the issue
https://ls1tech.com/forums/lt1-lt4-m...t-headers.html
Old 02-26-2009, 07:36 AM
kierstyn's Avatar
Yeah I knew the exhaust gaskets are square I have the pacesetters and the copper gaskets are huge didnt know if they would work. I will try a set of the square ones tho.
Old 02-26-2009, 12:59 PM
1badzee's Avatar
I used the coppers.. worked pefectly
Quick Reply: Gaskets for Dart heads
