Need help with nitrous !!
You will want to think about either putting in a colder plug or have a way to pull timing. Colder plug being the cheaper router as pulling timing takes either an MSD timing **** or if you opt MSD has a digital 6 which has a feature for that.
How does the kit activate? Does your friend have it on a microswitch or is in on a button?
Several things to consider, doing your homework like you are here will help alot. Good luck!
.. which system is better a throttle body plate or a nozzle system ?
and i do thank everyone for the help im real new to nitrous ive always been all throttle no bottle kinda guy but i do want to have my car setup right for it ..it does have heads and a pretty stout cam 1.6 rr along with a ported intake 58mm throttle body slp mass airflow, under drive ,msd opti , bbk headers full magnaflow exhuast , shift kit ,411 rear its just a stock bottom end but its been rebuilt so i think it will be ok for a 125 shot eh ? im gonna run 110 race gas 93 octane 50/50 at the track so im safe there ..i wont be using the nitrous on the street , im not really into street racing i like duking it out on the track ya know lol im just gonna use the giggle gas at the strip to impress the ladies hahhahah
think i should spray a bigger shot ???
