846 on lt4 valve springs stock rockers HP estimates
I have a Gm 846 cam in my car, full bolt ons, midtubes, ported polished airfoiled tb, no head work. I am currently running lt4 valve springs and stock rockers (due to budget constraints) here are my cams figures
12370846 Hydraulic Roller Design
This hydraulic roller design contains eccentric for mechanical fuel pump. It is for off-road use only. The duration at .050" tappet lift (intake/exhaust) is 222/230; and maximum lift with 1.5:1 rocker ratio (intake/exhaust) is 509/528. Valve lash is zero/zero and lobe centerline is 112 degrees.
I realize that this has less intake lift than a 1.6 rr hotcam, and slightly more exhaust lift, but with longer duration. I am wondering what hp numbers you guys figure I am making. And how much I'd gain upgrading my springs and going 1.6 rrs.
Any Ideas?
Any Ideas?
Good thing I've only clocked 30 miles on the motor since I built it. Is that a fact that it has the same lift regardless of rocker size? That doesn't make sense to me, either way I have since bought new springs I am just lazy and haven't installed them yet. Beehive crane's
Assuming I don't have serious valve lift, would my car still beat a hotcam 1.6rr car with the same supporting mods?
I can drive and have a nasty transimission, (viper build spec T-56, ram HD clutch)
Going from 1.5 to 1.6 will increase your lift to .543" intake and .563" exhaust thus increasing CFM if the heads support more airflow at the greater lift.
This cam has more duration, same LSA, and more lift (both with 1.6 RR's) than the hotcam so you can expect slightly better #'s.
With 1.6 rockers the lift will be .543"/.563".
You will have more higher lift and slightly more duration than the LT4 hotcam w/ 1.6 rr's. That should give you more mid-range and top end than a LT4 hot cam w/ similar supporting mods.
Yes I would sell your LT4's and purchase a better valve spring such as the Crane 10308-1 kit. The LT4 valve springs are barely sufficient for the LT4 "hot cam" and people even then have had issues. The Cranes are a nice spring and will allow you to run 1.6 RR's with your cam.
so you guys think that even given my 846 on 1.5's is only making .509 .528 lift that the springs will fail? I thought I'd get a season 0ut of em before I would be forced to replace them
