I want to turn the motor over without fuel or spark
I want to test my new valvetrain and maybe get some oil pressure up before I fire it up and want to crank it without fuel and spark.
Ive tried to pull the PCM IGN fuse but it just clicks when I turn the key. What else can I do? Is it safe to pull both injector fuses and crank it over? Or should I also unplug the plug wire?
Like I said in the OP I want to check that my new valvetrain is OK before I fire it up.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
"and maybe get some oil pressure up before I fire it up"
Wish there was a way to wire in one of those starter triggers so that you could start and stop the engine from outside the vehicle, like a remote start in a sense.
