I've been thinking: 2.25" TD's for quieter but badass sound???
I really love the classic chambered (sweet thunders) mufflers, but they hardly muffle, lol.
I will be running Cats, in hopes of killing sound, rasp, and smell.
I was planning on going 2.5" TD's all the way back but I'm scared I'll find it too loud, as it's my DD. I will also be lowering the car.
So I've started figuring why not go 2.25" TD's (this would be after the xpipe, because I already have pacesetter lt's and 3" xpipe that came together).
What do you guys think?
Check out the chart:
A 2.25” dual system is good for a 457hp engine with zero loss…
A 2.5” dual system is good for a 513hp engine with zero loss…
A 3” dual system is good for a 812hp engine with zero loss…
My plans for the car, at least right now and for the foreseeable future, is very simple. ls1 lid, full exhaust, suspension handling mods. Trying to not spend too much more money. Start saving for real life thinngs and a vette.
With your mods a 2.25" TD system will be more than sufficient, but I don't know what going from 3" to 2.25" would do for exhaust flow. Most kits I have seen are with 2.5" piping, which should not have a dramatic sound difference than the same exhaust with 2.25" piping.
smaller pipes will actually make the exhaust louder. 3" pipes are quieter than 2.25" pipes with same muffler. so if the only reason for 2.25" is sound then I wouldn't do it. but if your doing it for ground clearance and cost then its all good.
Less restriction = more exhaust noise.
Larger pipe = less restriction
Larger pipe = more exhaust noise.
I don't buy into the metal mass = sound absorbtion concept. More like a larger pipe provides additional area for resonance. Go to any muffler shop and they'll tell you larger pipe = more sound. Try talking to someone through a 1.5" PVC pipe then a 2". You'll get more sound coming through the 2". The larger pipe in effect acts like a megaphone. Using your theory, the additional mass of the megaphone should decrease the sound because of absorbtion, but it doesn't. Tail pipes are the same way. The larger diameter, longer tailpipes used on trucks increases noise output.
I also disagree with the chart in the first post. I've seen engines with under 350 hp run quicker (ie more power) just by stepping up from a 2.25 to a 2.5" exhaust that supposedly supports 457 hp w/no loss. Then you also need to consider RPM band, cui, and the use of power adders. Look a deisels. They're low HP, but they require a larger exhaust than a gas engine. So no, there isn't a cut and dry "use this size if you're in a certain power level" method to choosing exhaust size.
I have personally heard this before. a friend of mine had a old 55 pan head bike and the exhaust on it was a aftermarket set of i believe 2.5" straight pipes. he was going for a more old school look and swapped to much smaller pipes 1 3/4" i think (im guessing, it looked like the size of my header's primarys). and the sound was much louder and more raspy. a different friend had a 383 stroker malibu and bought the car with 2" straight pipe's with no H or X pipe and swapped them for 3" pipes with an X and the tone was much deeper but not as loud as the 2".
to me it seems to be that small pipes=louder at idle but quieter at WOT than big pipes
no it doesn't but weld up enough exhausts in varying sizes with similar muffler constructions/locations and you'll get a decent idea of what does what
if this were true a welded muffler in a stock catback would be louder than an aftermarket 3" catback with the same muffler, which it isn't
I was considering FM merge for a custom Y pipe and either a hooker or magnaflow catback, but I want some damn classic chambered mufflers.
I'm just gonna suck it up, and give the 2.5" TD's a try (all the way back though). See how I hold up.
It's gonna be sick though!
