Where to buy oil pumps
My Oil pump went out yesterday and since it is my DD i need to know where to buy theses parts ASAP in hope of getting it going again this weekend. I am looking into the melling M155 pump, or 10554 pump with the GM white spring and the Melling drive shaft. I have tried looking at summit for theses parts but to no success. Help would be GREATLY appriciated. Thanks
I started the car up, it had good pressure for about 2 seconds then the pressure dropped to 0. Was a quart low, so i filled it back up.pulled off the valve cover, started it and there wasn't any oil coming out of the pushrods.
ok, well i'm guessing its the plastic coupler. I DO have to change it from the bottom? can i pull the intake and replace it with the melling hardened shaft from the top? I have only found one thread on this topic and i'm pretty sure it said you cannot
i found the pump and driveshaft i need i just have another question and didn't want to start another thread. I'm wanting to know if i can replace the driveshaft by taking the intake off or not, or if i have to go from the bottom. Ill be using the melling steel coupler and new shaft.
no you change it while changing the oil pump. remove oil pan. remove 5/8 head bolt holding oil pump on and pump pick up and shaft should come out together. Is this a rebuilt motor??? Are you sure thats the problem? if a oil galley plug came out or you spun a cam bearing it will do the same thing
well tore the car apart last night. nothing wrong in the bottom end, so i put a new pump and metal drive shaft in. there were good size chunks in the pan so i'm expecting the drive gear now. Ill be pulling the intake soon. Can i get a new gear at OReilley's? part number maybe? thanks
